Question about Sony DAV-S300 System
DVD's will no longer play in color
We have owned the Sony DAV-S300 system for almost 7 years. We have never had problems with the system. A month ago we noticed that all DVD's that are played in this system now appear in black and white instead of color. We do not know why this occurred. We did have a dinner party for adults only and allowed all of the neighbor's kids to use our basement with supervision. We are not certain if the babysitter changed a menu option or if this problem even occurred as a result of this use. We have looked through all DVD and TV menu options and cannot find anything that would change the DVD's to be played in color again. Any help is very much appreciated. Thank you.
Re: DVD's will no longer play in color
Sounds like you're using the S-VIDEO output from the DVD player, but the TV is not in S-VIDEO mode. On my TV, not all of the input sockets support S-VIDEO, so make sure you're in the right socket (look for a TV screen icon with an S in it. Also, even in the right socket, it's possible to select the right input on the TV but not in S-VIDEO mode. On mine, I keep pressing the AV button to cycle through the inputs - when I get to the DVD one, it's black and white, but one more press selects the same socket in S-VIDEO mode and the colour returns.
Hope that's clear enough and that it helps (if you're still after a solution after all this time) :)
Posted on Nov 07, 2008
We had the identical problem, which was solved by changing the input channel on our Panasonic plasma screen. This was not obvious and we needed help from the person who installed the system. The input channel had changed automatically!
Posted on May 05, 2007
0 characters
3 Points
How is program?
It's explained in the manual...
Tuner Programming Page 17
Disc Play Programming Page 26
Feb 10, 2011 | Sony DAV-S300 System
Is it possible to use a universal remote control with my Sony DAV S300??
2010 September - Inexpensive Radioshack universal remote programmed all DVD functions - not the stereo - yet.
Aug 13, 2010 | Sony DAV-S300 System
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [RETURN] Default Default region code on the player
[1] [RETURN] Region 1
[2] [RETURN] Region 2
[3] [RETURN] Region 3
[4] [RETURN] Region 4
[5] [RETURN] Region 5
[6] [RETURN] Region 6
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[AUDIO] [RETURN] Default Auto switching ON
[ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[PREV] [RETURN] Enable user operation prohibitions* and access restrictions
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
Dvd is stuck on sony dv-s300 dvd player
i have same player and hhad this problem once i had to use somethin on both sides at same time to force it open(do it carefully and once you get it started it should engage and open on own like normal.) my button worked fine again on its own after that
Jan 07, 2010 | Sony DAV-S300 System
Is it under warranty?
Have you checked the manual for troubleshooting hints?
Can you bring in another device to try ( is there an AUX setting/plug in back)?
Jun 14, 2008 | Sony DAV-S300 System
Sony DAV S300
Contact tech support at Sony Consumer products...try the website first
Jun 02, 2008 | Sony DAV-S300 System
How to make sony dav-s300 dvd player multi region
Do you have the manual?
I'd check there first. You'll probably need the remote as well.
Jan 23, 2008 | Sony DAV-S300 System
Freezing and jumping when playing DVD's
Did you try to clean laser lenses? Maybe it's just a dirt.
Oct 01, 2007 | Sony DAV-S888 System
Audio problems
Have you tried playing around with the Audio after pressing DVD Display? May be your answer.
Jul 05, 2007 | Sony DAV-S300 System
Sony DAV-S300 System Logo
129 people viewed this question
Top Sony Home Theater Systems Experts
Dennis McCollum
Electro Med Services...
Are you a Sony Home Theater System Expert? Answer questions, earn points and help others
