Question about LG DLE5932W Electric Dryer
How do I remove the front panel from an LG DLE0332W electric dryer. It is kicking the circuit breaker and I want to check the drum rollers.
  • 706 Answers
Hello alloyd1455,
Please find a link for the service manual for your dryer and note page 26 and up discusses how to open up and gain access to the inside compartment.
Hope this helps
Posted on Dec 01, 2008
How to change a belt on a LG Dryer - DLE2101W
UNPLUG the dryer. Take the front kick panel off. Take the door off. Lift the top and rest it on something. Remove whatever is in front of the drum. Remove the drum. While you have everything apart check for worn pulleys and rollers. Place new belt around drum, and replace drum. Make sure belt is around the tension pulley. Replace everything in reverse order. Plug the dryer in and you should be ready to go.
Jun 07, 2011 | LG Dryers
LG dryer Model DLE3777W Very loud & rumbling, Drying times longer and not spinning as fast
Loud and rumbling usually means that at least one of the drum support rollers is not turning freely. It is a bit of work to replace them.
1. disconnect power to machine. 2. remove top by taking 3 phillips head screws out of back edge of top, then standing in front of machine, use palms of hands to sharply push top back about 2 inches and lift off. 4. remove control panel (you do not have to disconnect wires to it, just lay it on top of machine.) 5. remove screws at 4 and 8 O'clock positions behind door, screws along top edge of front panel, electrical plugs to light and door switch, and by tilting panel forward, the plug near the bottom for the sensor, allowing the front panel to be removed and set aside. 6. remove 2 phillips head screws from each side of drum support, allowing support to be lifted up about a half inch and removed, giving access to the front support rollers. 7. Release belt and remove drum to access rear drum rollers. 8. replace offending rollers and re-assemble.
I've skipped over a few minor steps which should be obvious as you go.
Feb 20, 2011 | LG DLE3777 Electric Dryer
How do we take the back off of the dryer?
After the top is removed, the front control panel, then the front panel, then the drum is removed to get to the rollers.
The back of the unit cannot be removed to remove the rollers.
Jul 25, 2010 | LG DLE5932W Electric Dryer
Drum won't turn-belt is good-motor
If you can manually turn the drum, the motor's start windings may be bad.
If you can't get the drum to move, check to see if a sock or other small item is stuck between the drum and the inside of the front of the dryer. If you see nothing, it's possible that one or more of the four drum rollers is/are seized.
Jul 15, 2010 | LG DLE2532W Electric Dryer
I Have a maytag Electric Dryer the dryer is
it could be your drum glides in the front of the drum or the rear center bearing or rear rollers, or the belt idler pulley or motor end bearings going bad,you will need to remove the front cover by removing lower kick panel screws near the floor and lifting upward on front cover,then remove top cover screws located under top cover and lift up and secure so as not to break wires to control panel,then rotate drum by hand and listen for noise location
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
I have a DLE 7177WM LG electric dryer is sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | LG DLE7177 Dryer
No heat, and my drum is cracked, too!
Measure the voltage (with a voltmeter) at the two slanted slots in the dryer power plug which should read ~220 volts AC. If at or near zero, there is no power from the breaker pair in the house electrical panel. Go to the panel and push the breaker pair to off, then on. Recheck the dryer socket again. If still zero reading, one or both breakers are bad (assuming that you didn't plug the dryer back in after checking the voltage). If you did, remove the dryer plug, reset the breakers as before, and recheck at the socket once again. If you now have voltage, suspect a short circuit within the dryer--likely the heating element. You will need to remove the drum to access the element area. Make sure that the entire air vent area is open and clean the filter in detergent and hot water. Replace the drum if it is catching on clothes
Aug 19, 2009 | LG DLE2532W Electric Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
Hope this helps.
Aug 27, 2008 | LG DLE2532W Electric Dryer
Lg dle0332w dryer something is in the tumbling gearing. sounds like loose change. I tried removing the panels but no luck like i have with other makes. How do i open the top, back etc
Unplug the unit or turn off the breaker. Back of the lid there are 2 screws, remove them and then slide the lid back. You may have to use some force. Lift lid and your in the unit. Couple screws to remove the front panel (control) and a few more including 2 inside the door and the complete front will come off.
Sgt 48
Jun 10, 2008 | LG Dryers
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
May 25, 2008 | LG DLE2532W Electric Dryer
LG DLE5932W Electric Dryer Logo
560 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
