Question about Denon DRA-397
Hi I have 2 denon dra-37>one connected just fine to my tv with the v-aux, but I can't get the other one to work. The unit is good, all of the other components are fine. any ideas? Thanks!
  • Kelanhurley Mar 04, 2009
    I have a Denon DRA - 37 and cant get my COX digital cable universal remote to control it. Does anyone know the 4 digit code?
  • basaradavid
    basaradavid Oct 03, 2012
    im also looking for the 4 digit code for the DRA - 37
A friend helped me connect things properly.Thanks!
Posted on Dec 01, 2008
Display reads "not connect" for v.aux input; how do I reconnect?
I would have thought simply making certain that whatever is connected to your Video Aux connection is actually in the socket and is not hanging out or even a faulty lead.
Apr 14, 2015 | Denon DRA-297 AM/FM Stereo Receiver
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
How do I connect my Denon DRA-75R to my new Vizio TV?
You can connect it only if the tv has Audio outputs. If it does then just use a 2-head RCA cable to connect it to the Aux input on the Denon.
Jan 12, 2011 | Computers & Internet
Denon DRA-37 Receiver-Remote lock on. Need to unlock.
Refer to the "Initialization of the Microprocessor" section of the manual (page 16 of the PDF version of the manual).
1) Turn the unit OFF using the On/Off switch (not the standby switch).
2) Depress both the Speaker A and B switches, and turn the Power ON.
3) The entire display should flash at 1-second intervals. The microprocessor should be reset, and the remote should be unlocked.
Jan 23, 2010 | Denon DRA-37
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Sep 01, 2007 | Denon DRA-37
Denon DRA-397 Logo
171 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
