Question about GE WBSR3140DW Top Load Washer
Ge washing machine pull knob
I was turning the knob on the machine to set the washer. Well I can pull it to turn water on but it seems to have disconnected. from the back piece. Which turns to the different settings. I can push on the back piece hard and get it to turn. But cant get the 2 pieces to stick together again. Do I need a repairman.
Replace the knob...The teeth on the back of it have broken.
Posted on Dec 07, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
How many times do you turn knob on timer to set
You have to push the knob in to set it for the program you want then push it in to start the machine . You can pull the knob out at any time to stop the machine .
Apr 29, 2014 | GE WBSR3140DW Top Load Washer
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Will not wash!!
Dangercart82,
I would recommend starting off by trying a different cycle. Change the dial to the spin cylce, or a different type (perm press, normal, knits) and see if it has the same problem.
-Davedwin
May 09, 2008 | GE WBSR3140DW Top Load Washer
Washer set up to go but................
First check to see if there is power in your wall socket by plugging in another appliance there. Then check the fuse in your washer plug, check wires too in plug..................
May 03, 2008 | GE WSXH208A Front Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
214 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
