Question about Proview PL926WBi 19" LCD Monitor
ProView PL926WBi Hello, I've got a ProView PL926WBi and pretty sure I need either a new inverter board or parts to fix mine. Both fuses are good and +14 and +5 volts coming out of the power supply board are good. Nothing comes out of the HV connectors. Tubes look ok and everything worked fine until one day came home to a dark screen which would not light up. I figured Windows was acting up so I powered all down for a few minutes and restarted. I noticed the monitor light blinking for a bit while the computer booted up, then the monitor looked as if it just shut off. Windows continued to boot, I'd expect fine, but nothing on the monitor at all. Any help would be appreciated. This is not an expensive monitor, so I really can live without it, but as I like fixing things, I'm giving it a shot. Thanks. -Rodger
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
ProView PL926WBi
this trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 000 170DTLBMH PI 190DTLB Proview 899 AB0 220DTLB PCTH Power Supply...
Posted on Nov 11, 2014
  • 558 Answers
Bad capacitors on the board, replace these and the inverters should get there power.
Posted on Mar 21, 2009
I need a base for a 19" PL926WBI LCD monitor. Have
i have the same monitor and it flashes on and off! i am willing to sell if you want to buy it
Dec 12, 2010 | Proview PL926WBi 19" LCD Monitor
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
I have a 19 Proview Monitor PL926WBI and it has no D-Sub cable or power cord, where can I get them realllll cheap?
Public sales or auctions from corporations or schools are the best places to get computer cables for very very cheap.
If you are looking to purchase new cables places like
http://www.pricewatch.com list competitive prices for the cables you are needing.
Jan 15, 2009 | Proview PL926WBi 19" LCD Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor flickering then shuts off
Capacitors are bad. I fixed one. There was 470 uf that was blown.
Go to electronics store and buy 6x470UF 25v. Thats how i fixed mine
Sep 23, 2008 | Proview PL926WBi 19" LCD Monitor
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
304 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
