Question about Dell OptiPlex GX280 PC Desktop
Dell GX280 I Have the exact same problem with my GX280 Dell. High speed fan and no boot-up. Did you ever find the problem with yours?
  • 4 more comments
  • edwardo_1010 Dec 05, 2008
    Some Dell amd 64
    Same High speed fans lights 3 and 4 are solid , no signals to moniter...but confirms connection to pc...
  • joe5286 Jan 02, 2009
    Got it to boot once, system froze after about 20 minutes. Shut it down (holding the power button), attempted to reboot and got the high speed fan and amber power light. Pulled off the heatsink and fan, removed the old thermal paste and applied new paste. System running cooler, but still won't even post.
  • esrarazvi Mar 17, 2009
    Solution posted by Glen Little is a temp fix. I did worked for me couple of times but No guarantees.
    Its good till you find a replacement MOBO.
  • Mark Burnett Mar 17, 2009
    My GX280 will not post either. Fan goes into hyperdrive and no signal to monitor. Tried removing memory and booting, then adding back just one card but still no signal to monitor and super fast fan. Any other ideas on this?
  • lionusman200 Mar 31, 2009
    I have Optiplex GX 280
    My computer give yellow light and fan start slows and then speed up with time
    My e mail adresss is lionusman2003@yahoo.com
    Pls mail me the solutin
  • Anonymous Apr 10, 2009
    Boots fine 80% of the time then screen goes black and it goes dark on the network then the fan goes into hyper drive and I have to unplug it and the other 20% it foes not get to the OS loading screen at all it just revs the fan up to full speed
Same problem... orange power light, fan starts slow and builds up to very high speed.
I removed my video card and SIMMs --> it beeped on boot and the fan did not speed up.
Put one SIMM back in --> booted fine, pressed F2 to view BIOS. Memory reported fine.
Put all SIMMs back in --> all fine now.
Posted on Mar 17, 2009
    Scholar:
  • 116 Answers
Diag Lights 3,4 indicate memory Failure (this could however be a motherboard or Power supply issue) see the manual on support.dell.com http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114558
try
1 - test memory - running on a single stick of memory and moving the memory around.
2 - test Power supply - swap with a known good PSU if possible
3 - Check for bulging capasitors on the motherboard (seems to be relatively common on these boards)
Hope this helps
Posted on Jan 05, 2009
Well i had a similar problem...on the internet i found the solution...put a half inch piece of rubber on the fan hood and press and close lid...now computer works fine although fand does speed occassionally...This is only for the SFO type of GS280
Posted on Jun 15, 2010
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell opti plex gx280 high speed for processor fan
if it is the speed control your looking for you need to go into the bios and look for the bios setting for overclocking there you shoul find fan speed control you can usually fing it in the chipset configuration
Jun 27, 2009 | Dell Computers & Internet
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
GX280 - is it the motherboard?
Go here and download this program.
http://www.download.com/SpeedFan/3000-2094_4-10067444.html
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Dec 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Nov 16, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
3,109 people viewed this question
Alun Cox
