Cannon 1120C Fusing Problem
I have a problem with this unit not fusing properly. The issue is on the right side from center out toward the right edge of the paper. I just installed a new hot and pressure roller, new oil felt and both cleaning webs. The toner will rub off the paper as it didn't get hot enough. To make things worse it is not on all of the copies. If I run 10 at least 2 or 3 of them will be ok. The rest of them the toner will come off of and you can see it on the back of the copies that came out before them. It is almost like the rollers aren't perfectly round. They are cannon rollers. I have adjusted the nip width and that doesn't change anything. The nip width pattern doesn't look like the picture that the service manual shows either. Instead of a concave pattern it is the same width across the paper from edge to edge. Can someone tell me what might cause the problem? I appreciate any help.
  • Edward Durre Dec 02, 2008
    Thank you for your response. I will check the paper settings to see where they are at.
    Thank you for the response. I will check the paper settings. I would ask about the nip width setting. I don't know what you mean when you say to make sure the front and rear settings match. I am only aware of the two allen head screws on the left and right sides that I can adjust the pressure with. The manual doesn't say or show anything other than these two screws.
  • 33 Answers
Make sure your print and copy settings are set for heavy paper. the most optimum paper I have found for this machine is 24lb. If you already have settings for thick paper and still get the same results try increasing NIP presure by 1mm at a time and test. Just make sure the front and rear settings match.
Larry
Posted on Dec 01, 2008
  • Larry Linch Dec 02, 2008
    By front and rear I mean the allen screw toward the rear of the machine and the allen screw towards the front of the machine. You are adjusting the ones I am speaking of. Remember to add only 1 turn to the screws at a time and do the NIP adj. Check the width of the thin gloss area at front and rear and confirm that you have only increased pressure by 1mm at a time.
    Larry
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Office Equipment & Supplies
How do I fix error code sc 548?
SC548: Fusing unit installation error -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
Possible causes:
Fusing unit is not installed
Poor fusing unit connection
Check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of position. SC 548 usually happens when a paper jam occurs and user does not properly fit the fuser back in place
The fuser may also not be fiitted properly due to some foreign object in between fusing belt and the sensor
From the panel, enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off, wait 30 seconds, the turn it back on.
To enter SP mode, press the yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button. from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Your machine should now be working.
Hope this helps.
Sep 04, 2014 | Savin Office Equipment & Supplies
How do I replace a Fuser ?
Sir/Madam
The Problem Is Very Simple ,You Need To Follow Few simple Step To Fix This Issue
  • Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  • Open the back cover (1) and the scanner unit (2) of the machine.
  • To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  • Hold the handles on both sides as you take the fusing unit out of the machine.
  • Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  • Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  • Move the fusing unit pressure release levers to the Set position.
  • Close the scanner unit and the back cover.
  • Turn the machine's power switch back on
  • Press the Menu/Set key.
  • Press the up or down navigation key to select Machine Info. and press Menu/Set.
  • Press the up or down navigation key to select Reset Menu and press Menu/Set.
  • Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
In case You Need More Help Then Go To Official Brother Printer Help Page Below:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000021/faq000021_002.html?reg=eu&c=eu_ot&lang=en&prod=mfc9420cn_all
Or If You Still Facing Problem Then Follow Us On:
Brother Printer Support
Jan 08, 2014 | Brother HL 2270DW Laser Printer
C-3721 error is displaying. How can I fix it?
Fusing abnormally high temperature detection (heating side)
Check the fusing unit, PRCB and DCPU for proper connection and correct or change as necessary.
Change fusing unit
Change PRCB
Change DCPU
Jun 28, 2011 | Konica Minolta Bizhub c203 Copier
Cannon 6218 fault e 000 not turn on
Hi harrisontim3 ,your problem in the fusing unit you can rest it by using short point in control board .
but it is difficult procedure if you are not expert ,so my advice tack it to service center.
Dec 31, 2010 | Canon NP 7130 Black and White Copier
Hi. we have a Sharp AL-1631 copier. It recently has been making a fairly loud + fast clicking sound upon startup and usually wrinkles up the first page through. It seems like the white plastic spring...
Wrinking usually is caused by the fusing unit. This is the part that gets hot and "fuses" the toner onto the page. I doubt that the cartridges are the issue. If you were getting binding or gears popping in the cartridge then your copy quality would be severely affected. Fuser drive gear failure is common on these models. Also if the noise is inconsistent then your right side mounting screw may be loose. Look at the fuser assembly behind the right side door. It is black in color and has the little green tab on the lever that has all the teeth on it. Looks like this:
Once you have the fusing unit located then look on either side of the unit. There is 1 screw on each side. Make sure they are tight. Especially the right side as that is where the drive comes from and is under the most pressure. If the noise happens all the time then you may have a broken or damaged drive gear on the fusing unit (upper fusing roller drive gear) or the small gear on the machine that drives the fusing unit. You can remove the right side screw and pull the fuser out enough to look at the gears.
Good luck and thank you for using Fixya.
Mar 24, 2010 | Office Equipment & Supplies
Error codes SC548 ricoh mpc3500, how can you solve?
The error means - Fusing unit rotation error.
Check if the fusing unit(right door{hot unit}) ,if it is rotating properly.
There could also be a sensor on the frame or the machine which senses the fusing unit rotation,(the sensor sometimes comes off)(remove the fusing unit and check where the fusing unit is seated).
Also try cleaning the sensor with a blower or brush.
Feb 13, 2010 | Ricoh Office Equipment & Supplies
Functional error SC548-00
- Definition -
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Error c3921 konica minolta c451 error c3921 not known what to do
C3921: Fusing sensor wire breaks detection (Center of the heating roller)...
• At the warm-up stage, the heating roller
thermistor/3 voltage does not decrease by
predetermined steps (temperature rise)
within a predetermined time.
upper right door.
Check the fusing unit, IHPU, PRCB and
REDB for proper connection and correct or
If that check still give you error code 3921
Change fusing unit
Mar 16, 2009 | Konica Minolta bizhub C450P Laser Printer
54 people viewed this question
k24674
jasbo
jasbo
