Question about Goodman GMS90703BXA Heater
Heater element ignites, but turns off before gas begins flowing which stops the process.
I actually have a GMT070-3A model Goodman furnace, but my guess is that it's somewhat similar to this one regarding this problem. What happens inconsistently is that the heating element lights up when the unit is getting ready to start heating (blower has been running about 10 seconds or so and continues fine through all of this), but the element turns off prior to the point where the gas starts to be emitted. And of course, whatever sensor is in there won't supply gas without a hot element. If this cycles 3 times, I have to turn the power off to the unit before it will try again (another 3 times if need be -- usually starts up during the second go around). Again, this problem is inconsistent. And the heating element works, just turns off sooner than it should at times. Not sure what's causing this or what to check/replace. Thanks for your time with this!
  • 3 more comments
  • Adam Fenton Jan 24, 2007
    Well, I think this one does. The gas appears to be ignited by the glowing heating element, and if the element isn't lit when it's time for the gas, the gas doesn't come out.
    Can you describe how to check the sequencers? Not sure exactly what/where those are. There's a circuit board in the bottom part of the furnace. Otherwise in the top part, there's the blower assembly, gas control apparatus stuff attached to end of supply pipe, heating element, 2 roll-off switches (not sure what these do, but that's what the manual calls them), and a flame sensor (on the opposite side of the gas-jet assembly from the ignitor).
  • Adam Fenton Jan 25, 2007
    Just checked the part heating element part. It's called a "Hot Surface Ignitor" in the Goodman repair parts document.
  • monstta Feb 11, 2008
    I have a goodman gmt070-3 when the thermostat runs a program the igniter turns on and the blower comes on then after about 10 seconds it shuts off because the gas doesn't ignite. It does this 3 times then it stops completely. I then recycle the thermostat turn it off then on then hold the temperture at 75 and the system ignites and runs fine.But it then turns on and of speatically. Can anyone help?
    I think it might be then flame sensor?
    Thank you
  • Anonymous Nov 29, 2008
    GMS9/GCS9 Warm Air Furnance
  • Anonymous Dec 02, 2008
    I have a Goodman Furnace (model GMT N060-3. My problem is that it does not ignite during the daytime. The ignitor will glow but it will not flame up and run. after about 2 minutes it shuts down and does not run. The induction motor starts up and the glow element lights up , but it just want fire up and produce heat. It appears to work at night after 7:00 pm but will not start up during the day.
Clean your flame sensor with a piece of wool
Posted on Feb 27, 2007
  • jenjeng Dec 06, 2010
    wool or steel wool? did this actually solve anyone's problem?
    New Friend:
  • 32 Answers
Do gas furnaces have heating elements? Have you checked the sequencers?
Posted on Jan 24, 2007
  • Aaron Galvan Jan 24, 2007
    For what I know, gas furnaces do not operate with heating elements. So you might want to check that first
He is right. the flame sensor is the culprit
Posted on Feb 28, 2007
I have a goodman gmp075-3 furnace, blower and igniter are working fine but not getting any gas to get furnace going
Check if 24 volts is being sent from the board to the gas valve, if not the board is nad and will need to be replaced, if there is 24 volts at the gas vlave terminals then the gas valve must be replaced.
Nov 08, 2012 | Goodman GMS90703BXA Heater
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
Furnace starts up blower starts..nothing ignites...then shuts down. repeats and doesnt stop...sanded igniter stick and nothing happend. flashes red once.
Do you see the actual ignitor glow? You must be saying that you sanded the sensor. The ignitor, after the little inducer fan comes on will begin to glow a bright orange until the burner lights. If the ignitor is broken, you will NOT see a glow, and you may smell a faint smell of gas.
Apr 14, 2011 | Goodman GMS90703BXA Heater
Heater unit will not ignite, will note fire up
Check your furnace by the electrical panel, there should be a blinking error light. Sometimes there is a legend to how many blinking lights means what. I had an issue with mine, read the code and it turns out it was hitting the high heat limit. Turns out my blower motor wasn't turning on. Replaced it with a spare and it was fixed. Find out what type of furnace, and google the name, model, and the words, 3 blinking lights. Does your furnace turn on at all? Does it start to go through the cycle then stop? This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
Mar 02, 2011 | Goodman GMS90703BXA Heater
Won't ignite
Be sure that that PVC vent pipe going outside is not plugged or trapped with water. If the vent pressure switch is not tripping the furnace will not ignite. Also be sure that you don't have a gas leak somewhere causing weak gas flow to furnace.
Dec 21, 2009 | Goodman GMS90703BXA Heater
Model #GMPN100-4 Goodman furnace. Vent fan
The sequence of events for furnace operation is -
Fan purge for 30-45 seconds. During this time, a pressure switch is actuated by the running of the purge fan, proving the control board the purge fan is running.
After purge and purge prove, the hot surface ignition and or spark begins. After a few second delay, the gas valve will open. The control board then monitors for flame prove through another sensor located near the burners. If there is no flame within 3-5 seconds, the gas valve closes. It will repeat this process, usually 3 times, before it shuts the system down, which requires a power down of the system to reset.
I have seen trash get into the hose between the purge blower and the purge switch. But you could be having other problems.
Dec 17, 2009 | Goodman Heating & Cooling
Goodman furnace went out. Light blinks four times
Your main limit switch is activated. Maybe for good reason. This switch keeps the furnace from overheating. I have the same problem right now and I think my a/c coil may be blocked, limiting air flow through the heat exchanger and the furnace. Does your gas and main circulating fan come on for a few minutes before the switch activates and the light begins blinking?
Check your furnace filter and any return air ducts in your home - see if they are blocked or restricted.
Jan 14, 2009 | Goodman GMS90703BXA Heater
Goodman GMP075-3 ignition problem
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace
Check the roll out switch(s) and the lock out switches. They are a small disc looking about the size of a nickle, with with 2 wires attached on them. There will be a re-set button in the middle that resembles a small peg. Push this in to re-set. As the glow coil shorted out, the fuse on the control board may have blown. On the newer furnaces find the main board and look for a car type fuse. If blown, replace. You also have the symptoms of a bad limit switch, by the clicking noise (the heat fan relay) and the blower fan running instantlly.
Jan 05, 2008 | Heating & Cooling
No heat, trouble shooting light has continious flash.
Try replacing the filter. Low air flow will allow the furnace to overheat. Sounds like a simple answer. Wish I had tried it before buying a flame sensor and controller. Live and learn I guess.
Nov 16, 2006 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
1,183 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
