Question about Refrigerators
Want to take the face plate around the ice and water dispenser off a Kitchenaid Superba Refidgerator?
  • gilb44 Dec 01, 2008
    Thank you very much! I could not remember from 1998 when the house was flooded and I took apart the refridgerator to clean it.
    Thank you again 20YRSEXP GREAT ASSISTANCE!!!!!!
    Gil
    Sergeant:
    Champion:
  • 311 Answers
Snaps off at two bottom recesses. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
How do you open the water/ice dispenser dress plate on a Kitchenaid Superba?
Not to be funny, but carefully. There are no screws holding the face plate on. Look on the bottom edge of the plate and you will see 2 slots. That is where the clips are that hold the face place to the fridge. They are molded as part of the plate and just snap off to remove the plate. This may take a lot of force and it is best to work at getting some 'flex' in the left side of the plate, then working your hands down until the snap lets go. Then lift and the plate will come off.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT
Jan 13, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
The water dispenser stopped working but the ice dispenser still works just fine on my KitchenAid Superba KSRG25QFB side by side
First Question, Have you changed the water filter???needs to be done every 6months. dirty water filter can keep water from flowing through system......also nasty to drink.........
Jan 09, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice dispensor flap does not stay shut
This is how most dispensers are accessed.
Check for screws around or on the under side of the dispenser trim that can be removed to get the trim off. Sometimes the drip tray in the base of the dispenser needs to be removed to access the screws. Sometimes the top panel (touchpad) of the dispenser is removed to access the dispenser components.
If there are no screws, use a putty knife with the end wrapped with tape so the paint on the door panel is not scratched.
Start at the bottom of the trim and CAREFULLY pry the trim away from the door panel.
There may be small slots in the panel on the under side that the putty knife can be inserted into.
With the trim off, the dispenser components can be serviced.
https://www.repairclinic.com/KitchenAid-Refrigerator-Parts
appliance parts, help & more
Apr 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Face plate around ice maker/water dispenser needs to be removed.
there are screws on the bottom of the plate. re,oive the drain pan underneith the dispenser and the screws are underneith that.
Apr 04, 2009 | KitchenAid Refrigerators
BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Nov 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
