Question about Sony Televison & Video
"High Pitch Squealing" from my tv.
I have a Sony FD Trinitron Wega, model #kv-36fv16 and it just recently started squealing. After about 5-6 hours of continuous operation it starts this high pitch noise, so I muted the tv to see if it was the station but not that lucky. Is the tube going out and if so, is it worth spending the money to have it repaired?
  • 1 more comment
  • Stevan McCarthy
    Stevan McCarthy Dec 01, 2008
    Hmmm.....so how much do you think it would cost to have this repaired?
  • Stevan McCarthy
    Stevan McCarthy Dec 02, 2008
    But it was helpful, it didn't fix anything yet. I'm still trying to get information, wouldn't you do the same? I do appreciate your time and help with this.
  • Anonymous Mar 29, 2014
    gas intermitten squeal on one channel only
  • 905 Answers
This most likely a coil or transformer that is doing this
And yes this is worth fixing , shouldn't be to bad on the cost of the repair
Posted on Dec 01, 2008
  • jason Dec 01, 2008
    you should not have rated me if you were not done asking me questions , and that rating hurts our rating by -.01% as only a fixya helps
    I will have to do some research on your tv and the part that is making the noise
  • jason Dec 03, 2008
    if your still wanting help then you should wait to rate my help since we were not done yet , and to fix it either I would have to physically fix it or you would have to be able to with the info i give you , but this will not be fixed untill the part is replaced , and if i can't hear the part that is doing it or if you can't tell me what part is making the noise then i cannot tell you how much the part will cost ,also repair shops vary in thier repair prices so that would be hard to say what they would exactly charge ( ecspecialy these days )you would have to call one to see if they will give you an estamate on the repair.
    coils can range from $30 to $350 depending on if the coil can be replaced or if the whole board has to be replaced because the tv company may only sell the board and not the part , transformers can range from $80 to $350 depending on if the whole board has to be replaced or if the transformer only is available. and to know how much the part will be most of the time you would have to have an account with the tv company to get the part and the price of the replacement.
    but after a while some parts are no longer available , so some research to find out if they are still selling the part will need to be done and if they don't then more research will need to be done to find a place that hopefully does sell the part or parts needed.
    and if that don't work then some more research will need to be done to see if another part can be used from another board on another type of tv (same brand )
    can you open the tv set?
    can you tell what part is making the noise?
    can you give me the identification numbers on the part that is making the noise?
    sometimes the noise can be stopped by plastic zip ties and a hot glue gun , (if applicable)or possible to do so.( depends on the part)( coil or transformer)(small coil or large , small transformer or large)
Why does my sony trinitron makes a high pitch noise when on and/or off ?
It's the flyback transformer. Check for bad connections on the flyback and on horizontal output circuit.
Nov 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Oct 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Picture fades in and out
SYMPTOMS
Distorted Video, Partial horizontal size collapsed, pop sound, or high pitch squeal.
RESOLUTION
In very small amount of cases the capacitors listed below MIGHT BE reversed on the A Boards below.
This was found at the factory and corrected but a few boards might have this miss-mount.
Capacitors C450, C616, C632, C638, and C650.
A-1302-981-A
KV-32FS120, KV-36FS120
A-1057-457-A
KV-27FS320
A-1058-449-A
KV-32FS320, KV36FS320
Jan 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega no picture
Sony has had problems with tuners for awhile.
Aug 15, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Televison & Video Logo
281 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
