Question about DISH Network IR Remote Control
Remote problems i have a remote that i cant use to turn off or adjust the sound on my tv im sure its some code or something if you could help id really be a happy person thanks
  • 8 Answers
I need the code for a 13" durabrand tv/ This tv was made for Wal-mart
Posted on Dec 14, 2008
  • 374 Answers
This is the preferred method of code searching our technicians use.
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
I hope this helps you and thanks for using Fix Ya.
Posted on Dec 11, 2008
Cant turn off tv
u probaly need to set the remote to tv, then put in the tv code. NOTE most if not every im not 100% sure but most convrters remotes only control just the power and or the volume on tv's
Nov 25, 2009 | Insignia Digital-to-Analog Converter for...
CANT FIDE CODE
Ask them, they are specialized in finding remote codes
Jul 08, 2009 | GE RM24911 Remote Control
Rca truflat locked
Hey this same thing happened to me not too long ago and you just have to buy a Universal remote and program it (it should come with the codes to program it to your TV) I think the code is 704 or 702 for RCA... Anywho after that then you can turn your tv back on wit the remote and push menu and Preferences and then FPA off. Its just a parental control block so your kids cant touch the tv buttons and mess with your settings.
Sep 25, 2008 | RCA TruFlat 27F520T 27" TV
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Feb 06, 2007 | Philips Magnavox 27MS343S 27" TV
NEED TO GET GREEN MENU ON
You some how got into the service menu, and your going to need to call an authorized servicer for this brand, and they are going to have to tell you how to put the TV back to factory defaults, If thats not possible, the sets going to have to be re adjusted and go through every alighnment to see what you changed. If that ever happens again, cancel out of that menu, as its for the trained tech to change things, as theres a process that has to be followed.
Sep 16, 2006 | Bush 1433GRN2 14" TV
How do I adjust the picture, I lost my remote..
Sorry Bud you cant. An original remotes available at http://www.remotes.com or 1800-remotes for about $61.00 + shipping. Without seeing a picture Im not even sure if thst will help ya man. If you wanna try to see if an alighnment will help then get the remote. I would advise you against doing any sort of technical alighnments as this set has high voltage around inside even afterv its been disconnected for a while. Good Luck
Jun 09, 2006 | Hitachi UltraVision 55HDS52 Television
DISH Network IR Remote Control Logo
322 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
