Question about Fossil Watches
My husbands watch broke at the buckle. The pin is missing and we can not find anywhere that has a big enough pin to fix the watch.
    Problem Solver:
  • 17 Answers
You need to measure the gap on the buckle to know how large of a pin you need. Usually in millimeters. A jeweler should be able to fix this with no problem. You can also go to Walmart and find a cheap watch that has the same size buckle and scavenge the pin from that buckle. Take your old buckle with you to make sure it is around the same size.
Posted on Dec 04, 2008
Does this leather band come out someway ? I can not see any pin holes ? My Husbands wants to switch it out to a buckle clasp instead. Is this possibile with watch ?
yes
under the band at the ends there is a small spring loaded pin that is removed and the band comes out
use something with a sharp edge , press in in beside the leather and then push sideways to compress the spring and the pin will come out
or take it to a jeweller and he will remove and fit the new band in 5 minutes
Feb 16, 2017 | Watches
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have a swiss legend keramica and i cant ajust the bracelet
Most bracelet adjustments require a special tool that is only found in a jewelry store, or your watch can be shortened by the manufacturer. Many watches have pins that push out if you look on the back of the band there should be arrows the pins push in that direction if you have something small enough to fit it the hole, be very careful to put the pin back in the same way. Occasionally some watch bands are not pins they are screws and it can be very difficult to tell the difference between the two. If the watch band has a screw it requires a very small screwdriver and you must be careful NOT to strip the screwhead! You can also shorten some watches by just moving the pin in the band buckle if you have a small tool you should be able to do this yourself, BUT wear glasses because pins will spring out, keep pointed away from your face. Hope this helps!
Sep 13, 2011 | Swiss Legend Karamica Beige Ceramic Watch...
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    I have the ladies parsifal (9988 A647707). The spring bar (?) broke off and the band needs to be connected to the deployant buckle. Where can I get this ultra thin spring bar?
    Any watch shop or jewelry store should have the springbar you need and will probably install it for you at no charge or for just a few dollars. Doing it yourself can be a frustrating experience and you could scratch the watch or buckle.
    Apr 20, 2010 | Raymond Weil Parsifal 9990CH Wrist Watch
    The pin that holds the latch closed broke. Where May I find parts to repair the clasp.
    You may want to go to somewhere that can repair watches or a jewelery store and they may have a box of junk watch parts and they my be able to replace that part, the buckle or solder it back on if you have the part.
    Dec 04, 2009 | Fossil CH2470 Watch
    The buckle fell off the band
    Hi Kap2000
    I know it's frustrating and I work in the industry the only thing I can suggest is to a Contact the manufacturer directly or try ebay for replacement bands? and Then rob the buckle off the new one to fit the old, so you still have the gift you gave to your husband?
    Model numbers would be useful if you wanted to email me I can try and help out further? (however in australia!)
    Jul 14, 2009 | Kenneth Cole 1213 Wrist Watch
    Watch band repair
    See if the buckle does have spring loaded pin like the ones that hold the band to the case.
    Mar 28, 2008 | Watches
    Watches Logo
    109 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
