Question about Bosch Nexxt 300 Series WFMC2201UC
PROBLEM WITH COLD OR HOT WATER
WHEN IS MACHINE SET ON REGULAR COTTON HOT WATER IS ALMOST COLD BUT NOT EVEN CLOSE TO 125 F.
  • aduvnjak Dec 01, 2008
    YOU HAVE RIGHT BUT I CHECK ON WATER TEMPERATURE WHEN IS RINSING AND WATER IS STILL COLD.I EVEN TURN MACHINE OFF IN THE MIDDLE OF CYCLE AND CHECK ON TEMERATURE AND STILL WATER WAS COLD
    Sergeant:
    Champion:
  • 311 Answers
Machine does not heat your water immediately. If water comes out of house valve cold at first then that is what goes into washer. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Inglis washer machine (#111-07) which we bought 2 weeks ago, doesn't use any hot water when set to the warm cycle (in between cold and hot), so i can only wash with entirely cold or superhot water...
Hi Elllie602 (!) from retired Englishman in SW France,
2 weeks old? Under guarantee/warantee? Get in touch with the vendor/shop!!!
Even if it takes only cold water for the warm wash (which is a bit daft- normally washers mix the hot and cold accordingly) and heats it, that is not how most hot n' cold washers work.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Whirlpool Washing Machines
Cold water runs hot even when hot water valve is turned off.
check to see if the cold tap is connected to the cold valve on the machine and the hot tap to the hot valve. on the machine it will have cold or c for the cold valve and hot or h for the hot valve. please reply if you need further help.
May 19, 2010 | Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
I need a washing machine that I can set for cold tap water
just shut off the hot water at the faucet and you will get 100% COLD water I guarantee this on any machine you buy
Nov 18, 2009 | Whirlpool GSW9800PW Washer
On the warm setting only get cold water. on the hot setting i do get hot water. please help
You might not be able to do much about this. It seems most manufacturer are concerned with reducing energy usage on washers. To that end, the biggest user of energy for a washer is not the motor, but the energy used to heat your water. Reducing the temp's will allow them to lower the energy used rating.
As an example, let's say you measure your cold water at a faucet and it's 55 degrees (of course this varies with the part of the country you live in. It is basically the average year round temp. Here where I am in Minnesota, that's about 44, but in Texas or Florida, it might be close to 70) Measure the hot at your faucet also, and let's say you get 125.
Now, if you measure the incomming water on your washer, the cold might be close to the cold measured at the faucet, say 60 in your area, but the warm might only be 70. Maybe not enough of a difference that your hand would even notice. Checking the hot, you might see not much over 100.
As I've said, the energy guidlines your government set forth are driving companies to make these type of adjustments. There is not much you can do about it short of re-wirering and possibly replacing the multi selenoid thermostatically controled water valve to make it into an older style washer fill system. The temp settings now are actually set to deliver temps which more accurately hit the ranges clothing manufacturers want when they say COLD, or WARM wash, in spite of your incomming water temps to the machine.
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Apr 01, 2009 | GE WBVH6240F Front Load Washer
When temp is set on hot water--hot water shuts off & cold water comes out
In the machine, you have a solenoid that the water hoses come into. That piece is controlled by a timer. The hot water during the cycle, does it shut off completely during fill or intermittent?
Mar 16, 2008 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
73 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
