Question about Kitchen Ranges
Burner problem one of the burners burn to maximum and contineously and does not stop unless i remove the plug from the socket
    Sergeant:
    Champion:
  • 311 Answers
Switch is bad-replace it. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
Will this use DVD-R discs?
Almost any CD burner made will use DVD-R media. They have been around a long time. The only media older than them is DVD-ROM. However, be advised that burners can be finicky in the brands of media that they will burn reliably. Also, never burn at the maximum speed of the DVD as this can cause unnecessary write failures. Always burn at least 1 speed lower than the maximum for best results vs speed. If you have trouble with cheaper, "Johnny's brand" media, pay the extra few cents and buy quality name-brand stuff. In the media world, it DOES make a difference.
Dec 10, 2015 | Computers & Internet
How do i change nozzel on oil burner
Turn power off and isolate the fuel line/lines. Disconnect flare fitting on fuel line to the burner assembly. Open burner assembly...either the primary controller or ignition transformer should hinge open with a few screws on the other side. Should be a locking nut on the fuel line to the burner and electrodes...loosen and pull burner/nozzle/electrodes. I Don't recommend removing the electrodes if you don't know how to space them correctly, so unless you have a nozzle removal socket/ratchet, then use a deep well socket & back it up with a large pair of channel locks. Thread pattern is normal...LLRT. When replacing nozzle, Make sure you have the same gallon rated, spray pattern (hollow, semi, solid etc) , & degree (angle).
Jan 19, 2015 | Kitchen Appliances - Others
Ejects cd from my dell inspiron 6400 and will not play or read
remove the CDROM (turn notebook around, remove the drive and reinsert after 1 minute.. perhaps it requires reseating.
if this fails, then accoding to Dell support Discs burned with this drive may not be compatible with some existing drives and players ; using DVD+R media provides maximum compatibility , if you have the 8x DVD/CD Burner (DVD+/-RW)
Jan 11, 2011 | LG GSA-T10N DVD RW Dual Layer Burner
The CD/DVD burner can read, but can not burn. At maximum speed, it produces an generic error. At low speed, it burns seemingly but the burned CD cannot be read back.
Hello Sir,
It has to be a software error I think. Better try any other CD/DVD Burning software. Let me know if the problem persists.
Aug 10, 2010 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
I get static on the CD in the background on a burned CD; what did I do wrong?
Four things come to mind.
  1. Low Bitrate- the higher the bitrate the better quality sound. If ripping mp3's I prefer 320kbps
  2. Burn speed too high- for good quality it's best not to burn at maximum speed. Although most CD burners will burn at 48X - 54X speed, select a slower speed (24X works well).
  3. Scratchy or poor media- it's possible that there's was a scratch on your CD or that you got a bad CD. Bargain CD's usually work pretty well but you will always get a few bad 1's in a spindle that end up being coasters.
  4. CD burner not properly grounded or plugs not secure. This is less likely unless it's an aftermarket device but still a possibility if you've done maintenance on your machine and pulled on a ribbon cable or power supply.
Hope this answers your question and solves your problem. Best of luck!
Greg
Nov 04, 2009 | E-Machines eMachines Desktop PC
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Sep 06, 2009 | NEC ND-2500A DVD±RW Burner
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
