Question about Acer Aspire™ T180 PC Desktop
Acer Desktop Won't boot up with new drive
I have a Acer Aspire T180 Desktop .. I am trying to install a new harddrive. The old drive (that came with the desktop) is hookup with the smaller cable, the new drive that I want to be the master is being hooked up with the wider (ide?) cable. I got a Boot Disk from Acer, that sets the drive up, also I got the recovery (back up) disk that came with the PC that I am using which is supposed to put the PC back to factory settings. I got through setting it up / installing the disk ... I try to boot PC up, and it says not a system disk. It appears the PC is not reconizing the new hard drive as the boot disk (I did change it in the boot menu).
I have taken the drive out of the pC, and put in another PC, and the computer picks it up, and runs windows Xp with no problem.
Help please
Frustrated
  • 6 more comments
  • dktozer Dec 01, 2008
    Tks for the help .. but (LOL)
    I was able to disable the SATA, set the new harddrive as the first boot.
    When the PC starts up ...
    I get ...
    VERIFYING DMI POOL DATA ....
    BOOT FROM CD:
    DISK BOOT FAILURE, INSERT SYTEM DISK AND PRESS ENTER
    Still stuck !!
    d.
    I don't have a floppy drive on my PC, I do have the orgianial install XP disk, can I do it from there ?
    Tks for your help on this ...
    d.
    A thought .. if the harddrive is missing boot files, it wouldn't boot on my other machine right ??
    A the XP disk ... I was hoping to do the restore with my Back Up files that came with the PC, so that all the drivers, etc. are there already ... the restore of back up is supposed to put it back to factory settings ...
    Still trying ...
    d.
    And that is where my problem is ... I load the back up disk to the new drive., and the PC does not reconize the new drive as the boot disk ( I am sure the boot files are on it). I am guessing I am not doing the right setting in the CMOS to have the PC know that the Master is on the IDE, not SATA.
  • dktozer Dec 04, 2008
    Thanks for the help, finally decided to take into local shop ... had them replace harddrive. According to them, alot of my problems came from faulting CD rom, not loading windows properly.
  • dktozer Dec 17, 2008
    The funny thing ... when I do the restore, I can take the hard drive, put in my 2nd PC, and it works.
    For what ever reason - It won't boot from the hard drive.
    I checked, bios, etc.
    Hard drive is set to boot from.
  • Loteck May 11, 2010
    Strange. I guess some computers are more picky than others. There is usually a jumper on the mobo. It is usually in plain sight. I don't remember the remember the number but I think it might be J1,J2 or J3. Set it to the center pin and the open pin. Turn on the computer and see what happens. It seems to reset something. IT might boot,it might do nothing or it might tell you to change the jumper back. If it boots great. If it doesn't set it back to the original position and power up. Beyond that I am out of ideas.
    Do these "restore" discs work for anyone? It sounds to me that it will only restore the OS that is on the original HD. I don,t know if it will allow you to install XP on a new HD. This is how Microsoft keeps people from installing XP on an unlimited number of computers.
    Sergeant:
    Champion:
  • 274 Answers
Go into your CMOS settings and make sure the DVD/CD drive is set as a bootable device, and that it comes before the Hard Drive in the device boot sequence.
Posted on Dec 01, 2008
  • 69 Answers
You need to go the bois settings.... be careful there of you don't know what your doing.
The smaller cable is SATA and the one you are trying use is IDE.. your computer is set to SATA primary drive. You need to go to advanced seeting and change some seeting around to accept the IDE as primary. Please be careful you could end up messing your system if you don't know what you are doing. Please all the changes when you make them.
Please me know if you need telephine support at the time you do these changes.
regards,
Philip
  • 2 more comments
  • Kuldip Singh Dec 01, 2008
    This issue can be caused by any of the below reasons.
    If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
    To resolve this issue:
    • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
    • Once at the A:\> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
    1. Corrupt boot files on the computer.
    2. Settings for hard disk drive are not correct.
    3. Floppy diskette or CD in computer causing issue.
    4. Boot devices not set properly.
    5. BIOS corrupt or misc. setting not set properly.
    6. Connections loose or disconnected.
    7. Bad Hard disk drive or other bad hardware.
    Please let me know how you get on..
    Thanks,
    Philip
    Thanks,
    Philip
    I don't know where you live but I would like to help with this... please do the following if you haven't already.
    Go into your CMOS settings and make sure the DVD/CD drive is set as a bootable device, make sure that your xp cd is inserted in your drive.
    Regards,
    Philip
    Hi, if you have a recovery disk which came with your computer or that you created when you first got your system, will do. That disk will restore to your computer to the factory settings.
    Let me how you get on, or if you know need further help.
    Regards,
    Philip
Acer aspire t180 stuck on logo screen
try booting in safe mode by tapping f8 during boot
Oct 09, 2012 | Acer Aspire T180 PC Desktop
I have a acer aspire t180 desktop with a 250gb hitachi scsi (ide) hd. I would like to know which hard drives are compatible so that I can exchange it. thanks
It's a SATA harddrive, not SCSI.
Serial ATA
Acer Support > Aspire T180 > Specifications >
http://www.acersupport.com/acerpanam/desktop/0000/Acer/AspireT180/AspireT180sp2.shtml
Will use up to a 400GB SATA harddrive according to Acer.
IDE stands for Integrated Drive Electronics.
Another name is PATA.
Parallel ATA
Used to distinguish between IDE and SATA.
1) http://en.wikipedia.org/wiki/Integrated_Drive_Electronics
2) http://en.wikipedia.org/wiki/Serial_ATA
3) http://en.wikipedia.org/wiki/SCSI
Exchange it?
Your harddrive has the Operating System on it.
A new harddrive will not have an O/S on it.
(Windows XP is an example of an O/S)
It would be much easier to install the harddrive you wish into an external enclosure, and plug the external enclosure's USB cable into your T180.
One example of a desktop size harddrive SATA external enclosure,
(3.5 inch SATA external enclosure.
3 and 1/2 inches across in width, for a desktop harddrive.
Laptop HD's are 2.5)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Jun 18, 2010 | Acer Aspire™ T180 PC Desktop
Pc doesn't boot stops at set up
Your computer is having some problems at POST. Try removing one of the memory dimms you have installed. In case you have one leave it like that and remove Hard Drives, optical drives, any usb devices on the back and try again. In case it boots start attaching the hard drive and try again.. if it boots, add the optical drive and so on until you get the failure.
I hope this helps.
May 06, 2010 | Acer Aspire™ T180 PC Desktop
My Acer T180-EA381B desktop won't burn dvd's over
The DVD Drive iteself may be bad. After installing/reinstalling the drivers, there are only two things left to check and that is if the driver was installed correctly (device manager- check to see if there is a "?" mark next to the DVD drive) or you can buy another drive and install. A new drive should take cae of your issue.
Nov 13, 2009 | Acer Aspire™ T180 PC Desktop
Trying to start up an acer aspire T180
can you tap F8 while it is booting and start in safemode or select boot with last good know configuration?
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
Nothing on desktop aspire t180
If it is new and only a few weeks old, take it back to where you purchased it from as if you want the restore cd's from Acer, they will charge you $20 or $40 plus shipping.
I hope this helps.
Good Luck.
Feb 26, 2009 | Acer Aspire™ T180 PC Desktop
Acer Desktop won't boot after recovery
Why not use your new hard drive as a storage disc. Reconnect your old hard drive as it was before. Hopefully it will boot the computer again. If it does, shut down the unit. On the primary bus, set your old HD as master & the new HD as slave with jumpers. Boot the unit & hopefully you will now have a "c"&"d" HD showing in My Computer. Remember that your are dealing with Windows & what should happen & what really happens can be two entirely different things.
Dec 14, 2008 | Acer Aspire™ T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
Dec 17, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
388 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
