HELLO MY UNCLE PASSED AWAY AND HE LEFT ME A COMPUTER THAT HE WAS BUILDING I NEED TO FIND A BOOK ON THE MOTHERBOARD THE BOARD IS RED AND THE NUMBER ON IT K8M80-M7A . ON THE COOLING FAN IT SAYS AMD IT WAS BEING BUILT FOR GAMING, IF YOU KNOW WHERE I CAN GET INFO FOR IT I WOULD LIKE TO FINISH THE COMPUTER AND USE IT THANK YOU FOR HELPING ME
  • 4,806 Answers
Ok, go here and click where is says manual:
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=209
Enjoy and don't forget to rate please
Posted on Dec 01, 2008
  • 69 Answers
I suggest that you type in the number on google, but before you do that there should be a name somewhere wrriten in white this name will the make of the motherboard. some like "agus"... let me know if you need more help.
He should have had supplied to him the motherboard drivers at the time of purchase, you will need them.
Please let me know what happens.
Regards.
Philip
My uncle has passed away. He used my pc. I wish to delete his screen name as no one uses it anymore,
You can delete your uncle's user account and files by -
Click on Control Panel - User Accounts - click on the user you want to delete and delete and remove the user's data.
Jul 24, 2011 | Dell Computers & Internet
Tip
How to Choose Memory (RAM) for Your Computer
You need memory for your computer. But how should you choose the right kind? Whether you're upgrading your computer or building a new one, learn now.
Step 1 If you bought your computer from a manufacturer, use a search engine or go to the manufacturer's site to find the specs on your model. The max RAM found in the specs is likely the max RAM the whole system supports. To find the largest size module the system supports, divide the max supported RAM by the number of slots. Also listed in the specs should be the max speed supported and DDR type (listed as DDR, DDR2, or DDR3). Alternatively, instead of max speed and DDR type, the specs may list something like PC# ####, where the "#" is some number. This is just a different way of representing speed and DDR type, and works equally well in finding the right RAM. If you know the largest supported module, max supported speed, and DDR type, skip to the Tips and Warnings section.
  • Step 2
    If you're building a new computer, follow the above step, except search for motherboard model specs rather than computer model specs. If you don't know the model, look for it printed on the board.
  • Step 3
    If you couldn't find your computer's specs, the info wasn't detailed enough, or you have a custom-built computer, go to http://www.gtopala.com/siw-download.html (also in the resources below) and download the freeware SIW. Install and run it. On the left side, under the "Hardware" section, select "Memory."
  • Step 4
    The "Memory Summary" section on the right side shows the maximum amount of memory that can be installed in the system (listed as "Maximum Capacity"), and below that is the number of memory slots (listed as "Memory Slots"). The "Device Locator" sections tell whether or not memory is installed in that slot. To get the largest size module the motherboard supports, divide the "Maximum Capacity" by "Memory Slots." To get the speed and type, look under the "Device Locator" section, for the listing "Memory Type." Write down the PC#-#### part, where "#" is some number. Also for the listing "Speed," write down the value in parenthesis. For example, in 333 MHz (DDR2 667), write down only the (DDR2 667). You now have the largest supported module, RAM speed, and DDR type. You can use either the PC#-#### or the speed and type when searching for RAM.
  • Step 5
  • In Step 4, you found a supported RAM speed, but it may not be the fastest supported. Just to make sure, look to the left side in SIW. Under the "Hardware" section, select "Motherboard." Using this info, go to the manufacturer's site or do a web search, and see if you can find what maximum RAM speed the motherboard supports.
  • Step 6
    If you're building a new computer and need to buy RAM, look up the specs on your motherboard to find out what kind of memory it supports.
  • Step 7
    The RAM you buy should be no larger than the max supported module size, and should match the type and speed supported by the motherboard.
    Open source site for computer pc error fixing software site is on http://digitalpowering.blogspot.com
  • on Jan 08, 2010 | Computers & Internet
    My husband had a Sony cd player that he used alot. He passed away 3 yrs. ago and I have not used it till now. I put a cd in and it will play for short while, then stops and the red light in front comes on....
    Hello
    Long duration of unused condition will make its laser head assembly to be infected by fungus. You haven't used this device since 3 years, and so the possibility is of 90%. If you have a lens cleaning disc, put it into it and play for three or four times. Sometimes this may help you. If not replace its Laser Pickup Unit, with same type and number. OK.
    Mar 09, 2011 | Sony Audio Players & Recorders
    Stuck on Philips Welcome Screen
    I need help with that too :O my uncle used my mp3 player.. he passed away and it is very precious to me. :(
    Mar 03, 2010 | Philips GoGear SA3245/37 Digital Media...
    How can i see the name of motherboard in my computer?
    Open cpu cabinet of your computer.
    Then you can see your motherbord there.
    Read carefully on motherbord there is model number and other information for your motherbord.
    Note down chipset number and other info.
    Let me know if you need further assistance.
    Thanks.
    Nov 04, 2009 | Mercury P4VM800M7 Motherboard
    Front panel connectors
    hey its in manual book which u got wit MB pack
    Sep 18, 2009 | Intel Motherboard
    Problem find the intro book
    You don't need book, plug in try, plug in try, pin are located on the bottom right hand side of board you will see SW, SPKR and so on that is what you want, twisted black and red are speaker, then you may also have USB those don't go there they will go on the left or middle of that section, also just try you'll get it, thats how I always did it
    Jul 16, 2009 | ASUS A7S8X-MX Motherboard
    SD102 missing the key
    Hi.
    Yes, you need the key to open it.
    Your code is 4 numbers (one or two digits each).
    First turn the knob several times counter clockwise To "reset for starting)
    Turn the knob clockwise. Stop when you hit the first number the fourth time. Then counterclockwise, and stop when hitting the second number the third time. Counterclockwise again until you hit the third number the second time. Counterclockwise, and stop when hitting the fourth number the first time.
    Now you need the key. The safe opens when you turn the key clockwise. I don't know where to order a new key, but I suppose the manufacturer can help. Your key number should be engraved ON the lock. Mine has four digits lock/ key- number.
    I have not been able to find the manufacturers web page...
    I wish you luck!
    Stein/ Norway
    Jul 08, 2009 | Safe International Digital Electronic Safe...
    Gateway 40000287 Motherboard Intel Pentium ---- Manual? anywhere?
    try tom's computer hardware on line or go to intel .com its probably a intel board surf the web under motherboards . when I was building machines thats what i used to find out about boards i would pickup at computer flea markets. Over clockers . com
    Dec 31, 2008 | Gateway Computers & Internet
    Constant restarts,
    if you get passed the bios setup menu and it reboots when getting into windows, you have to start your pc with the windows disc to do a repair, as you have changed the hardware and windows is looking for all the motherboard drivers, but only finding your old ones. If your are building the system from new then there must be a video or memory fault, so long as you now the cpu is working ok.
    Sep 08, 2007 | Biostar P4M80-M4 Motherboard
    Computers & Internet Logo
    314 people viewed this question
    David Payne
    David Payne
