Question about Sony KV-32S20 32" TV
No video on VIDEO 2...cold solder connections on video and audio inputs...resolder, but solder pad for video has no connection ...looking for a pictorial view of the PC board to insure there is a connection ..Can you direct me to where I can find print outs of the PC board for a sony KV-27V20...Chasis is BA5
I just fixed this on my TV. With the small front input board removed from the tv, solderside up and the rca jacks pointing away from you begin.Looking at the board in this position locate RCA video jack. Directly in a row are 2 comparitively large solder pads. The pad furthest from the RCA jack and closest to you has a thin trace that runs from the noted pad to a solder pad on a small surface mount component marked 750. That small trace is not making contact on the solderpad that is soldered to the RCA jack. To fix it take a small metal pic or tiny flat screwdriver and scrape away some of the PC board coating right on the trace where it meets the solder pad, and place a small solder bridge on it. Thats it put it back together and watch TV. Thanks to all the members here who post solutions. Frank
Posted on Jan 30, 2009
Television was alright when it was cut off. Next morning cut it on and the picture is all yellow and blue.
Tv is missing a color green,recheck ur tv Ant.hole coaxial cable input.Take the cable apart and reconnect to the Ant.hole again see if this help?Not make a fist with ur hand bang on the tv back cover frame see if the color green come back or flashes?Yes,than the tv CRT video board that is connected to the CRT- picture tube have cold soldering joints around it video board connections sockets,require resoldering the socket joints connections between the CRT video board and CRT tube connections socket.U have tools like a soldering iron,a roll of solders and can do basic soldering work?Yes,this problems just require resoldering that it.
Jun 10, 2011 | Sansui DTV3200 32" TV
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
After switching unit off for two months while derorating, put tuner back into use and it keeps switching on and off intermitantly. tuner was put into cold bedroom while off - any ideas
Sounds like cold solder joints inside the unit...if you know how to solder you can take unit apart...look at the main pc board and see if you see some connections that look like they have cracks in them. A solder joint should be shiny and solid...if it looks like it may not be solid and shiny you can resolder it to make it like new again. This may solve your problem
Dec 19, 2010 | Marantz ST4000 2 Channels Tuner
I purchased my Sony KV-35S66 in Dec. 1999. The screen is black when I turn it on. Sometimes, it will show the picture for about 45 seconds, then it disappears. The audio is fine. Have the picture tubes...
No,this tv is fixable.The video board,that the board,that connected to the CRT (Tv Tube),those round pins holes that connected CRT sockets that hold the CRT(Tv Tube) and the video board together.Resolders those CRT pins sockets that connected on to the video board.Will solved the cold solders connections between the CRT pins sockets and the video board this problems,will be solved.Tries take it to a tv shop,ask them take the tv aparts,resolder the video board CRT pins hole sockets on the video board for you.The priced my guest about $35-40.They must,take tv cover out and resolder the vdieo board CRT pins holes sockets.The whole job,take about 20-30 mins.
Oct 28, 2010 | Sony KV-35S66 35" TV
Audio video jacks on crt tv cut out ie if iam playing a game the video or sound will cut out or both will cut out.
The most common issue is bad connections where the jack assebly solders to the main board. If you have solder experience take the set apart and look at the solder connections and resolder if needed. Please take a moment to rate my answer. Thanks...
Nov 23, 2009 | Televison & Video
Player works fine, speaker works fine but screen is blank...
This dvd player is having a problem with the video input /output circuits. This could be a minor problem with a loose connector or some over expanded solder joints. It could also be a problem with the video ic have a problem with its circuits. The connector problem and the possible cold solder joint problem can be repaired. The dvd player must be taken apart and the connection cleaned and repaired. If the problem is with the video solid state components, you will have to have it repaired by a service center. The video has a main ribbion connector that connects the laser lens to the main board video inputs. This ribbion cable usually will run under the laser transport mechanism. It is connected to the main board and laser transport by clamping connectors. You can look and see if this connector is loose or bent and has lost its function. Try cleaning the contacts points of the connectors and the connectors on the main board and laser transport.Also look for bad or cold solder joints in the areas of the connectors. Try to resolder these points.Use new solder to insure a good connection. Remember to only work on these dvd player with all power disconnected. Always wear anti-static wrist bands and gloves when working on the dvd player to prevent further damage. If the cleaning and repairing the of the possible cold solder joints do not repair the problem, you probably have a bad video chip and should replace the dvd player.I hope this information helps you with your problem.
Mar 21, 2009 | Mintek MDP-1815 Portable DVD Player
Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Feb 06, 2009 | Kenwood 1090VR Receiver
Pioneer model sd 582hd5 Video goes out
cold solder connections on the video pc board assy.
Aug 23, 2008 | Televison & Video
No Picture Audio Only
It sound like the components are ok. Are any of the component leads discolored from excessive heat? If so it may be that the resolder looks ok but is not actually adhering to the lead. Use solder wick or a desolder iron to remove the old solder, clean the lead(s) by scraping with a sharp knife edge to bare good metal and resolder.
Dec 08, 2007 | Mitsubishi WS-55315 55" Rear Projection...
My Sony TV KV32s45 32" Shows no picture but has sound. After a few houres of unpuging the TV the screen is good but then the picture gose up and all i see i a black screen but the sound is good. THE stanby...
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
Intermittent video or snow
Resolder points A, B, C, D in tuner PCB, check cold solder on tuner shield 2-106-349-21
Nov 23, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
187 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
