Question about Marantz Audio Players & Recorders
Marantz home theater receiver is clipping after I hooked up surround speakers. Sound cuts off for a few seconds.
    Top Expert:
  • 14,162 Answers
Posted on Mar 21, 2016
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
ohms
  • 1879 Answers
SOURCE: Not getting proper surround sound
Greetings,
I would like to refer you to leethedeuce, he knows more about audio system setups.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 08, 2008
SOURCE: marantz sr 66u receiver
KAKO SI MIMI
Posted on Dec 19, 2008
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
OnlyOneN
  • 86 Answers
SOURCE: How do I connect my Lenovo X200 Tablet to my new
Couple things to be aware of:
1. The X200 is not available with a Blu-Ray drive. So, your HD content will need to come from somewhere else, such as downloading from iTunes. Alternatively, you can purchase an external Blu-Ray drive. (it may be cheaper / easier to buy a dedicated Blu-Ray player if that's the route you want to go).
2. The X200 only has analog audio output. The only surround you'll be able to receive is Dolby Pro-Logic, provided your source material has it encoded that way. You can connect your laptop to the receiver via a 1/8" to RCA adapter, available at virtually any electronics retailer. (Buy the cheapest one you can find) Connect the 1/8" plug to your headphone jack on the laptop, and the white and red RCA connections to any available input on the back of your receiver. (such as CD, AUX, DVD, etc.) Select that input on the front of your receiver and you'll hear the output of your laptop. Enable surround sound processing (pro-logic) on your receiver. Check the manual for instructions on how to do that.
3. Purchase a VGA cable (I recommend monoprice.com ). I suggest staying under 15' for optimal quality. Connect one end to your laptop, and the other to the PC-in on the back of your TV. Select that input using your TV's remote. (On my Sony, I press Menu, External Inputs, then PC)
4. Set up your laptop to use the external monitor. I suggest leaving your laptop off till you plug in the VGA cable. If upon booting your laptop is outputting to the TV display, usually a key combination such as Shift-F7 will enable it.
Alternatively, your TV has an 1/8" audio input jack that goes along with the PC input. If you've connected the audio out of the TV to your receiver already, the audio from your laptop can pass through the TV to the receiver. 1/8" cables can also be purchased from Monoprice.com.
Let me know if that helps!
Posted on Apr 20, 2009
High frequency noise form my 7.1 surround sound system
Is the microphone live? If so, what you're getting is called "acoustic feedback". Any room sound gets in the mic, gets amplified, comes out the speakers, and then gets picked up by the mic again. Louder and louder until you get to the maximum your system can do.
The solution is to turn it down. . . until it stops.
May 13, 2015 | Acesonic HKR-710 340-Watt 7.1 Surround...
How to connect new flat screen tv with hdmi cable to an olin ross sound system 6050 home theater 1000 watts
Evidently this system is a speaker system that hooks up to 5.1 home theater receiver. I've included a few quote on how to hook up the 6050 system:
" Measure and cut wires running from the speakers to the receivers"
Read more: http://www.ehow.com/how_10058195_hook-up-olin-ross-or6050.html#ixzz33bqoGyyY
"Run the wires from all speakers and the subwoofer to the back of the receiver".. The key is to have a home theater receiver, then you can hook up the TV to the receiver.
Jun 02, 2014 | Computers & Internet
Awia speaker ok for home thaeter
Just about any speaker will work for home theater. As long as it makes sound.
Of course, you will need some type of surround sound processor (like a surround receiver) and other speakers to connect to the front left, center, front right and surround connections.
Some speakers will work better than others.
I will not get into any specifics because there is WAAAAY to much information to get into. Do a little research on home theater systems and how to design, hook up etc.
May 02, 2014 | Aiwa Audio Players & Recorders
No sound center channel
Check the speaker output settings on the receiver. The receiver may be in a 'stereo' or 'two-channel' mode only.
Mar 05, 2014 | Marantz SR6006 Home theater receiver...
How to connect martin ash system to tv
If you have a surround sound system at home and you have speakers with it you switch your speakers with the Martin ash speakers and hook them up the same way you have your old surround sound speakers but if you do not have a surround sound system already you need a receiver
Apr 30, 2012 | Mitsubishi Audio Players & Recorders
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Tried to hook surround sound to home stereo system and shorted out. home theater comes on but no sound to surround speakers
I need to know what system you are using, what speakers you want to use, and what decoding system you want to use...accordianman
May 01, 2008 | Audio Players & Recorders
83 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
