Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
Iomega HDD80 GB external drive isn't recognized by new computer
Just set up new Dell running Vista x64 and my Iomega HDD80 external drive (about 4 years old or so) isn't even picked up as a new drive or "seen" by the computer. Is there a remedy for this?
  • 1 more comment
  • editart Dec 07, 2008
    I don't understand what you mean by "connect it as a secondary drive" and checkout. Please explain further. I am a normal person, not a techie.
    I don't understand what is mean by "connect it as a secondary drive" and checkout. The computer does not SEE the drive when I connect it via USB, it doesn't even know it is there. Please either explain further or suggest a different handling. Thanks, Daveda
  • editart Dec 29, 2008
    Thanks for those who offered suggestions. The iomega drive works fine on my older computers, but it still does not make any sign of life on the new Vista x64 bit computer. I suspect that the drive is completely incompatible with Vista x64 and wondered if there is any way around this. The USB ports are fine and work with other equipment. So I'm assuming that nobody has a solution to this? Thanks again.
    Novelist:
  • 159 Answers
The drive is simply not supported by Vista -- and Iomega does not support Vista with that drive.
Look here:
https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/cci/platform.php?prod_lvl1=3&prod_lvl2=765&p_prods=3,765&p_pv=2.765&p_sid=y8FvNJkj
Sorry for the bad news. You can buy a 1tb external hard drive for well under $150 shipped, and get some 12 times the space. A friend with XP can help you move your files over, or you can download something like Knoppix, a bootable CD, which should allow you to mount the new and the old drives and copy files over.
For what it's worth -- that hard drive has some of the worst reviews I've ever seen on Amazon. It's just painful. You have to move on.
Posted on Dec 07, 2008
  • Boogerhead01 Dec 07, 2008
    Some additional routines for trying to get unsupported drives working are here:
    http://www.vistax64.com/vista-hardware-d...
    I don't know how much time this is worth to you.
    Some drives simply do not support Vista.
    Yours is one of them. There is nothing you can do to change that.
    You can get an external 1tb drive, some 12 times larger, for less than $150 shipped. A friend with XP can help you move your data over.
  • 6,487 Answers
If the new computer can detect a different USB devices, so the problem here is the external drive that you have, you can try first to use a different USB cable because sometimes its just a problem with the cable....
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it has to be determined whether the USB port of the new Dell running Vista or Iomega HDD80 is the issue. Pls try:
  • plug in any other external storage device to the Dell such as a flash/thumbdrive, digital camera, eternal memory card reader and the likes; and/or
  • try the Iomega in another PC.
Should it be determined that that Iomega works in another PC, then the Dell would require attention. Perhaps an update would be needed; If on the other the Iomega would also not work, then it is highly probable that the internal 80Gb hard disk of the Iomega would need attention/checking/replacement.
If the above solution has merit, pls click on my "Ask Me" to explore further or rate as you see it fit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • Louie  Role
    Louie Role Dec 29, 2008
    Have you tried USB drivers update or roll back on the Vista?
  • 73 Answers
You should be able to install the drivers for it if you got any discs with it then try installing them again if not try and go on the companys website they usualy have a download for the drivers, however since it is 4 years old the drivers may not on the downloads part of the website if so then try look for a contact us and e-mail them with your problem
    Sergeant:
    Champion:
  • 347 Answers
Hello Editart,
1- make sure your USB (if this is how you are connecting it) is working. You can try to plug other devices on that port to check if it works.
2- If it does conect your external harddrive and right-click on "My Computer". Then select manage devices. See if your harddrive appears in that list (also make sure to check the "?" list).
Good luck and let me know what you found so far to continue helping you.
Dahaka
    Sergeant:
  • 217 Answers
Connect it as a secondry drive and checkout.
    Genius:
  • 1,847 Answers
Did you tried it on a different computer?
  • Legin Varghese
    Legin Varghese Dec 01, 2008
    Place you hand on the HDD and chk if you feel the drive spinning.
    If no the Hdd id dead.
    If yes go to my computer and check for the drive there.
    Install the software if any that came with the HDD.
    Try some other USB device and check whether that is detected
    If no reinstall the chipset driver.
    Let me know if you need further assistance...Kevin.
  • Legin Varghese
    Legin Varghese Jan 05, 2009
    did you check the omega website for latest vista driver. i think you should you should try that.
I have a iomega eGo 500GB which I used on a dell laptop running Windows XP. I backed up all my files on the drive and now have a new laptop running Vista (old laptop has gone) put whan I pluged in the...
Enable "File and Print Sharing" on the "old" computer.
Connect the IOMEGA to the "old" computer.
Enable file-sharing on the "root" folder of the IOMEGA.
Connect the "old" computer to one of the LAN ports on a router (wired or wireless).
Connect the "new" computer to another LAN port on the same router.
Make sure that both computers are in the same "workgroup".
From the "new" computer, browse to "show computers in my workgroup".
You should see an icon for the "old" computer.
Double-click that icon to "open" that icon, and you should see all the files on the IOMEGA.
Copy those files to the 'C:' drive on the new computer.
Nov 11, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
I have a new 500GB Iomega external harddrive. It is now loaded to near capacity with films etc. When I plug it into my USB port on my Sony TV it does not seem to be recognized. When I plug it into my...
1. The TV and drive may not be compatible with each other. 2. The formatting of the drive could be the problem. The USB memory stick would be formatted as FAT32, but the Iomega drive would have been formatted as NTFS. Maybe the TV can only read drives formatted as FAT32 and not NTFS.
Jun 28, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
Iomga eGo drive data back-up for Vista need transfer to Windows 7
try to connect it to another computer that runs vista, reformatting is never a good thing. the portable hould be read on any other computer, but if you connect to another computer that have vista take it off and keep it on the other computer for a little (like someone elses computer) and put it back on to the computer with windows 7, reformat it and try to put our stuff back on then try again.
Jun 19, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
External hard drive will not mount on my mac
Bet the drive is toast. Get the correct software and do diagnostics on drive to confirm
Sep 21, 2017 | Iomega 33089 250 GB Hard Drive
My external hard drive does not work on windows xp
You might need to initalize it in XP and then assign a drive letter.
Aug 29, 2009 | Iomega 250GB Ego HD USB 2.0/FW Red 250 GB...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Jul 24, 2009 | Computers & Internet
Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
NTFS hard disk not recognized as 'RAW' iomega hdd160
format this with NTFS to recognize by your computer, RAW means no file system
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Unable to install IOMEGA HDD on Vista Home Premium
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
Oct 18, 2007 | Iomega 32883 40 GB Hard Drive
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
82 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
