Whirlpool duet sport turns off after pushing start button
Model # WFW8410SW, turns itself off after you press START BUTTON. in detail. i pressed power button, selected cycle, pressed start and then machine turns off. don't have a clue, as i used the machine the day before and operated perfectly. the only thing i did that was unusual, but should not be an attributor. i used gentle cycle and it has low spin for the spin. when cycle was finished. i used the spin and drain on high spin to drain out remaining water in clothes. after 10 minutes of cycle, i canceled the cycle. i don't see how this could be a problem, but i hope it helps.
4 Suggested Answers
sdmc73
  • 121 Answers
SOURCE: whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Posted on Nov 29, 2008
  • 311 Answers
SOURCE: LED works, but when press start power turns off Whirlpool Duet Sp
No reset, control is probably bad. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Posted on Apr 06, 2009
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
May 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dec 01, 2008 | Washing Machines
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
