Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
Lisa Barla Posted on Feb 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with Sony Handycam
To whom it may concern, I'm not sure what the problem is, but when the camera is on the only thing visible in the viewfinder and the LCD screen is lines. Everything is very distorted. I would greatly appreciate your help. Thanks, Lisa
Anonymous
Level 2:
  • Expert 169 Answers
  • Posted on Aug 15, 2007
Anonymous
Expert
Level 2:
Answers
169
Questions
0
Helped
85525
Points
213
Ccd image sensor of your camera is already damage...go to the sony service center for replacing the ccd...the model of your camera is one of the recall products due to the factory error of the ccd image sensor production...
The display on the Sony Handycam DCRSX63 does not snap.
If the display on your Sony Handycam DCRSX63 is not functioning properly, there are a few things you can try to fix the issue:
  1. Check the battery - Make sure the battery is fully charged and properly installed in the Handycam. If the battery is low, the display may not function properly.
  2. Check the connections - Make sure all connections between the Handycam and the display are secure and not damaged.
  3. Reset the Handycam - You can try resetting the Handycam by turning it off and then on again. This can sometimes resolve any issues with the display.
  4. Update the software - If you have not done so recently, you may want to try updating the software on the Handycam. You can download the latest software from the Sony website.
Tape error
that means the CCD thet is at the back of the lens is bad,and it need to be changed
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
I dropped my SONY HDR-SR1 Handycam with LCD open. LCD cracked in 3 lines. Display 75% visible. Touch screen still works. Over time display now 50% black 50% visible. I have downloaded the Service...
LCD's can be replaced althhough it is really not a user serviceable problem and will usually need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
1helpful
I JUST BOUGHT A USED SONY HANDYCAM DCR-TRV27 MINI
Congratulations! Please use the following link to download Manual, Operation Guide and other things.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRTRV27
Play back fuzzy
It looks like dirty video heads. Put brand new tape on camera and play it all the way to the end several times if necessary. It will clean the video heads. Good luck!
Nothing in viewfinder or on screen
Same thing happened to me. Seems to be 'common' although Sony says they have no recall on the CCD. Look around the forum and you will find others with the same problem.
3helpful
2answers
2helpful
No Audio only video is visible.
Replacing the speaker part number 152959011 2,0 cm should solve the problem. If you need more info please advice. Arpi
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
