Question about Toshiba Satellite A205-S4617 Notebook
Can i connect toshiba satellite a205 to tv?
I have toshiba satellite a205 which has rgb port. i bought converter connect rgb and other side has rca port that connect to tv. is this rgb allow to see picture from laptop to tv? RGB port connection is same as VGA??
  • tburro0318 Mar 22, 2009
    I have a Satellite laptop with a VGA port that I use for a printer. Can I use that to output to my TV that has a DVI/HDMI port?
  • Anonymous Mar 31, 2014
    want to connect Camrecorder
  • 29 Answers
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
Connect toshiba satellite l640to with RGB port out to HDTV
you need vga to rgb convertor/adoptor to view on tv
Jan 14, 2013 | Toshiba Computers & Internet
I have a Toshiba Satellite L655-S5096 and am trying to use the RGB port to connect the laptop to a relevision. I'm attempting to use an adapter to convert to an RCA style plug as the tv doesn't...
I have tried this on several occasions with different models of VGA to RCA converter boxes and the resulting screen images have always been extremely POOR.
If I were you, I would not bother spending any money on one of those converters. Just save the money and put it towards a decent computer monitor or a good flatscreen TV with a VGA input connection.
You can pick up a good old CRT computer monitor for next to nothing these days since everyone is just throwing them out and changing over to the flatscreen monitors. And if you want, you can even pick up a small brand new flatscreen monitor for about $100, so there's not much reason really to mess around with those questionable converter devices.
Good luck anyway.
Jul 28, 2011 | Computers & Internet
Can I connect my LG flat screen tv monitor to my toshiba satellite L505D-GS6000 labtop. There is an HDMI-DVI IN port on the back of tv. On laptop I don't see an HDMI port but there is an RGB (monitor)...
Ok in order to hook up the laptop to the TV you have 2 options
First option.
Buy something like this
http://www.amazon.com/Sewell-Converter-All-One-Cable/dp/B003BVVYSM it will directly interface your laptop with your tv. The benefit will be you will get sound to your tv from the laptop
second option.
you will need a vga to hdmi cable like this one
you can buy this here
now this option will only let you have just the video from your laptop on the television because a VGA cable is a video only cable and port.
I hope this helps you.
Apr 19, 2011 | Toshiba Satellite L505D-GS6000,...
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
I have a toshiba satellite 2210 and i want to
You'll need to go to a store and find a converter cable. Honestly, most stores won't carry something like this, but it's possible that you'll find one. I found a bunch on eBay. Here's an example of what you're looking for. They come in a wide range of quality and prices, but this is basically what you're looking for. If you wanted a really high quality one, you should go for an actual converter device, and not just a cable where "magic" happens inside. Here's one I found:
http://cgi.ebay.com/VGA-to-TV-S-Video-RCA-AV-OUT-Converter-Adapter-Cable_W0QQitemZ250417764135QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a4e0fd727&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1308%7C301%3A1%7C293%3A1%7C294%3A50
How to convert my my toshiba laptop w/ a usb port or a rgb port, to my jvc lcd 46' hdtv 1080p. is there any downloads that can help. I would like to have a nice media center.
I am unsure that yours is the same as mine (mine is a equium p200d-139)
It has a svhs socket onthe side and on the F5 key is the pc/tv switch ( by pressing the fn key and f5 you go from screen to svhs and screen then just svhs then back to screen)
If you have such a socket just connect a svhs cable to the tv and power the tv up, select the svhs (mine is shared with av2 on my tv (sony))
you may have to go into display options in the control panel also.
I hope this helps
May 04, 2009 | Toshiba Satellite L305D-S5874 Laptop
Toshiba Satellite A205-S4617 Notebook Logo
1,249 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
