Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
The power led light keeps flashing
I ve got the shiatsu massage cushion,the one without the heat,the power light keeps flashing and nothing else works,what do i do?
  • 1 more comment
  • Kev_Kerwin Apr 22, 2009
    The lights Flashing and when i click power it makes a click, and the balls are stuck at the top... nothing seems to be working...
  • Anonymous May 16, 2009
    flashing light, no movement
  • Anonymous Aug 07, 2017
    I also had this problem with the blinking red light on the power LED function. I had to unzip the back cushion using a standard household spoon edge to expose the internals, Then I proceeded to remove the 3 phillips head screws covering the wiring connectors junction box. Once I pushed all of the electrical connectors back into the circuit board seating them firmly, it work perfectly afterwards. P.S. Do these procedural steps ONLY with the unit UNPLUGGED in order to prevent an electrical shock or malfunction of the unit.
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Posted on Dec 19, 2008
You can also open the unit and move the rollers assembly with your fingers a little to get the whole massage unit back on track. Make sure its not plugged in. Smoothsn
Posted on Nov 01, 2009
Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunki
mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
Oct 13, 2017 | Homedics Quad Roller Massaging Cushion...
Conair massager model 4502ST
I have a homedics shiatsu massaging cushion model SBM-300. I have lost the power adapter. The box says 120VAC/12VDC 1A. I cannot find a replacement anywhere. Any help would be appreciated. Thanks
May 02, 2012 | Conair Heated Back Massaging System Bm1
I bought my partner this Massager for xmas, it worked fine for 2 days and today, when he plugged it in, there is no power!!! Any advice please? Thanks
I actually Bought The Same thing for My partner There Was nothing you Could Really Do Besides taking It back And Getting Another! Sorryy But Hoped This helped!
Dec 27, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this...
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Oct 02, 2017 | Homedics Shiatsu Massager
It's on but nothing is happinging
Well for starters, it doesn't hurt to keep all of your receipts in an envelope, especially for warranty purposes. I have one of these, and because they cost so much money, I couldn't just leave the receipt lying around.....No-one will take something back these days with-out proof of purchase, so you might want to start keeping your receipts somewhere handy.....I hope this answers your question :)
Dec 25, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Wiring poitive and negative
Hi, I have an SBM 500H massage cushion without that AC-DC adaptor... may I know whats the working DC Voltage in Volts and DC Current in amps it works on? Kindly, email me at stycch@yahoo.com... Thanks!
Feb 04, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
I have a Shiatsu Massaging Cushion....it will not operate...blue power LED blinks.
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/massage
Jan 03, 2009 | Homedics Shiatsu Massager
Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
Nov 27, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
5,121 people viewed this question
Top Homedics Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
