Question about Philips 9P5034C 50" Rear Projection Television
5yr old philips rear projecter tv color bad 50inch
Cant adj color real strong blue in pic plus not clear do i need new bulbs or new tv
  • Anonymous May 14, 2009
    red screen
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directi5yr old philips rear projecter tv color bad 50inch - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
5yr old philips rear projecter tv color bad 50inch - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
How can you tell if the bulb is burned out on a RCA 52 inch projection
If you are missing one of the colors but still have an image (red, green or blue). Real simple, turn on the TV and see if there are any colors missing from those. Most rear projections have a color bar you can put up or a converge feature which is used for aligning the colors for a clear picture.
Aug 31, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My philips 55pw9363 has yellow tint I took off the back the blue bulb has no pic in it like the other two but light is bright
It means you have Bad Coolant Fuild in the Blue Tube,most of the time it will be the green and blue tubes and it needs to be changed and New Coolant Fuild put in it. Philips is the worlds worst having bad coolant fuild in tubes.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 22, 2011 | Philips 55PW9363 55" Rear Projection...
The pic is real brightand blue waypoint missed up
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 01, 2010 | Philips 55PW9363 55" Rear Projection...
How much for a bulb for a 46'' Rear Projection Tv? It only has red and green need a blue bulb.
Anywhere from $100.00 up to $500.00 depends on New or used but good. On these TV it usallly needs New projection fliuld ,Blue is always one to fill with new fluild.look down into top of tube if it is not clear fliud is bad.
Sep 18, 2009 | Philips Televison & Video
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Bad color blue green bad pic tried adj covergence no luck
The problem is either poor solder connections on the convergence ICs ore defective ICs. If you can solder, you can fix this yourself. Be aware however, of dangerous high voltages that are present even with the set unplugged. The ICs are STK392-120s and should be attached to a large heatsink. Try resoldering the pins first. If that fails to resolve the problem, replace the ICs.
Dan
Dec 29, 2008 | Philips 60PP9202 60" Rear Projection...
Bad picture
A 10 year old Rear Projection tv is usually at the end of its life. No such thing as "fluid". Best advice, get a new TV.
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS 55PW9383
You can get the repair manual emailed to you after purchase at the following link its the full service manual 2400 plus pages you need the DPTV 340 service manual in their Phillips catagory on the left side.
Jun 21, 2008 | Philips 55PW9383 55" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
380 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
