Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Power my sansa e250 is glowing but wont turn off or on completely it seems when i plug it in to charge it acctualy drains it
  • 8,596 Answers
Make sure the hold/lock is not engaged.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My mp3 sansa won't turn on or charge.
If it freezes up, wont charge or just wont turn on... slide the power button up for 15-20 seconds then turn it on. That should work everytime. good luck
Aug 13, 2009 | SanDisk Sansa e250 MP3 Player
Sansa MP3 Won't charge or come up on computer screen!?
sometimes if the mp3 is very cold or if it has been completely drained from battery it will do that, first try using a charger that you might have for your car, or something that you can charge it from a wall outlet.
Jan 29, 2009 | SanDisk Sansa e250 MP3 Player
My e250 will not turn off & will not turn on-Screen is gray w/vert. lines in it
You need to remove the battery and let the system power down completely. I have had this problem and the others I have seen on this site. Removing and reinstalling the battery solves many problems. Just letting the battery drain is not good for it and may take a really long time.
Sep 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
hold the power button for a SLOW 20 sec, then power up with NO PROBLEM!
Aug 31, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Sansa sandisk
LOOK AT THESE WEBSITE FORUMS...THEY ARE FOR THE SANDISK SANSA PLAYERS
http://forums.sandisk.com/sansa/search?submitted=true&q=E250
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 turns white
try resetting (holding power button for twenty seconds)
or letting the battery run out and charging it
still not working?
did you get a warranty, or did you buy it recently, you may be able to take it back to the storee you got it from orr send it back to the manufacturer?
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
i know i have to charge my sansa for at least 7-8 hours before the battery will show it is full. about your other problem, i believe there is an option under the settings menu to automatically shut your sansa off. If not then you can turn off the backlight and that will save alot of battery life.
Mar 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
