Question about Canon PowerShot A550 Digital Camera
Canon Powershot A550 flash will not work it just blinks on & off?
In the picture window of my canon powershot a550, the flash will not work. it no longer flashes and the camera still takes pictures as long as I dont use the flash option. If I do use the flash option, the little flash icon will blink on and off over and over and over again. I tried to reset my camera and I even tried new batteries and the flash will still not work. Any ideas?
  • 734 Answers
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
  • antonio8880 Jul 24, 2011
    I had the same problem I had just take a litlle "tap" in the opposite side of the flash and it´s working fine! I just dont know for how long!!
The dude may be right.
In August out of a sudden my flash stopped working. Then after 4 months of taking photos without flash surprisingly it resurrected. Then again it stopped working. Now as when I turn it on the flash is always dead, but when I press the locked door hardly and the grey "card/batt. open" usually It fires... So in my case it's not a matter of the fuse, but rather of the lock although I just don't get it why the flash needs to have the battery lock strictly closed...
Posted on Dec 08, 2008
  • grannygear Sep 07, 2011
    I had the same problem and searched for hours until I found this page - I searched for hours until I found this site -http://camerarepair.blogspot.com/2007/11... Apparently removing the memory card and reinserting it before you put in the batteries fixes this and also my problem of the flash not working. Did it, works now.
    This also works to stop the "change the batteries" message appearing when you know you put in fresh ones. Apparently some things have a memory and this erases it.
4 Suggested Answers
jobsagoodun
  • 156 Answers
SOURCE: for the Canon PowerShot A550, card is locked
Pop the card out of the camera- there's a tiny switch on the card that locks it so you can't write over important photos.  Move the switch to the other position and you should be good.
Posted on May 06, 2010
  • 11967 Answers
Move the slide switch on the side of the card.
Posted on May 10, 2010
  • 11967 Answers
SOURCE: canon powershot a550 " lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 18, 2011
Lost Digital Camera Solutions Disk for Canon PowerShot A550
Try this
http://download.cnet.com/ZoomBrowser-EX-Updater-for-Windows-XP/3000-2192_4-24035.html
Mar 14, 2011 | Canon PowerShot A550 Digital Camera
For the Canon PowerShot A550, card is locked
May 10, 2010 | Cameras
May 06, 2010 | Canon Cameras
Remote shooting on Canon PowerShot A550
The software that comes with the A630 is generic to the whole series of cameras with different capabilities. Some have this feature, and some, like the A500 - A600 series, do not. Do not feel bad though. Many of the cameras that do have this capacity cannot do the photo-stitch picture merging that your camera does.
Jun 14, 2008 | Canon PowerShot A550 Digital Camera
Lost software
hello coolhottie
you can get the softwware and more from here Canon Australia - PowerShot A550 .
riz.
Apr 17, 2008 | Canon PowerShot A550 Digital Camera
A550 powershot flash not working
we all need new flashes it costs 90 bucks to replace it
Mar 06, 2008 | Canon PowerShot A550 Digital Camera
Connection problem with Computer
ya.
first reinstall the camera software. if it dosent work there s some problem in your Operating system. try these. if it dosent work. please inform me
Dec 08, 2007 | Canon PowerShot A550 Digital Camera
Canon PowerShot A550 Digital Camera Logo
550 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
