AHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!! every time i plug in my headphones i have to hold the cord at the right angle to play in both or it dose not play at all, or it plays in just one how do i get the music in my mp3 to play on both earphones
    President:
  • 2,992 Answers
Try another pair of headphones first to determine if the trouble is the phones or in the player. The wires in the headphone cable are very thin, and flexing at the plug often makes them break inside.
If the problem is in the player, it's usually due to solder connections breaking where the jack joins the circuit board. These connections might be repairable. If you can open the player in the first place (the case on many brands is either glued together or the halves are held together with plastic tabs that are nearly impossible to open without breaking the case), and if the jack has a style of solder tab you can reach with a normal iron (many use a type that requires special soldering equipment), you might be able to resolder the connections. These things were never intended to be repaired, even by the manufacturers. Under warranty they just replace the unit at their expense. Out of warranty, you do.
Posted on Dec 01, 2008
Dont work when i put them into headphone slot. i have to twist them and most of the time hold them at one angle to get them to work... i have the skull candy skullcrushers.
It is broken wire(s) inside the cord at the plug. The is either get a new jack at Radio Shack or similar and solder the wiers to the contacts as follows bare copper (2 of them) to the "sleeve" which is the part of the plug closest to the cord, then solder each of the other two wires to one of the other contacts.
May 19, 2010 | Skull Candy Skullcrushers Headset
Right headphone will not play music
sounds like a broken wire. have them exchanged.
Mar 22, 2010 | Bose in-ear headphones - Black with...
I can only hear the music and not the lyrics on my skull candys
You have a separated wire in the cord. this causes not only a disconnection, but can also cause an increase in resistance in the cord as the signal tries to bridge the gap in the conductor.
Personally I have had this happen many times on headphones with straight connectors right where the wire comes out. This happens because the wires can only bend back and forth at a right angle so many times before they break. I use a 3 inch long piece of shrink tubing just large enough to fit over the rubber part of the plug and use heat to shrink it down. this forms a sort of poor man's strain relief on the wire.
Sep 17, 2009 | Skull Candy Ink'd Stereo Ear Bud...
If I jiggle the cord in the stereo outliet, the sound switches from left to right earpiece and has to be just right in the outlet to get both earpieces working at the same time.
If you plug the headphones into another device do they stay on solid?
The problem can be the cord/plug (headphones) or the socket which your plugging into. Socket might need re-soldered or replaced.
Jul 26, 2009 | Bose QuietComfort 3 Acoustic Noise...
Loose Wire, please help
You will have to buy a replace ment jack and solder the connections. These cords seem to have different colors between manufacturers but start by soldering the green or blue (left) to the tip of the plug, the next ring to the red(right) wire and the base to the copper(ground) wire. Try to get a plug with a metal shield that unscrews and make sure you thread the cable through the shield right way around( threads towards plug before you solder.
Apr 21, 2009 | Skull Candy Lowrider Headphones
Ipod (30 G) earbud jack only plays out of one ear
Does this still happen with a different pair of headphones? If not, get another pair. If the same behaviour with any headphones you will need to contact Apple if still in warranty to get it repaired.
My bet is with the headphones not the IPOD.
Good Luck
Mar 18, 2009 | Apple iPod MA446LL/A MP3 Player
Its the same as AHHHHHHHHHHH!!!!!!!!!!!!!!!!!
It is a common problem with the c200 series...what I would recommend you to do is to call sandisk to see if they are willing to send you a different player...
I hope that helps
Please accordingly
Thank you
Computerrep
Oct 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
The internal cable of your Headphones is broken somewhere ....replace the Headphones
Oct 18, 2008 | SanDisk Sansa c200 MP3 Player
Bose headphone sound
try cutting your cord and reconnect it using electric tape...
Jun 19, 2008 | Bose on-ear TriPort Headphones
96 people viewed this question
 Grubhead
Grubhead
