Question about Dacor Preference SGM365SS Gas Cooktop
Where in VA do you get replacement rings for DACOR SGM365S burner knobs. These are the rings that go around the control knobs?
    Sergeant:
    Champion:
  • 311 Answers
Appliance Parts Depot in TX. Look it up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
I have a 5 burner Dacor Cooktop (SGM365) with which I am having trouble with the right rear burner not sparking. There is gas flow and the other burners are lighting just fine. I've taken the burner apart...
In the middle of each burner, there is a small brass ring that screws in the burner. If you unscrew all five and pull the knobs, the top should come off. From there you can access the electronics. Because all the burners ignite at the same time, I would suspect either a disconnected or shorted wire on your right burner or some corrosion has occurred at that burner preventing it from grounding properly.
Nov 09, 2009 | Dacor Preference SGM365 Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
I melted the knobs for my dacor cooktop and the model number for the cooktop is: SGM365S.  What do I need to order and from whom? Thanks, Sanford
You will have to order from a dacor dealer. Check with the manufacturer for a dealer near you. try 1-877-DDS-DACOR
Jan 28, 2009 | Dacor Preference SGM365SS Gas Cooktop
Need to access the burner controls from underneath the top panel
visit manufacturers web site and click on support and enter model number
Dec 08, 2017 | Dacor Preference SGM365SS Gas Cooktop
DACOR SGM365S 5-Burner
Appliance Parts Depot in TX- look them up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Dec 01, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Oct 22, 2008 | Cooktops
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM365SS Gas Cooktop Logo
93 people viewed this question
Top Dacor Cooktops Experts
Mike
Mike
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
