Question about Aiwa Z-L520 Shelf System
Casset cover door will not open when pressed
My casset door on tape deck 1 will not open when I press it. I have a tape in it that I would like to get out. Is there anothet way to open the door. Nickname: bob711
  • Anonymous Jan 23, 2009
    Cassette door sometimes does not open unless you pull on it a little bit . also tape deck will not play on either deck .
    Novelist:
    Champion:
  • 218 Answers
You probably have one of two problems. Either the tape has been eaten by wrapping it around the capstan or else the head has not retracted to let the door open. If the tape will still play, then it is not the first problem. If the tape will not play, then it could be either problem. If it is the latter problem (head not retracted) then you may have a bad belt (broken or slipping). The tape wrapped around the capstan problem may be caused by a belt or tire being bad but a different belt or tire than the head not retracting problem. This may seem confusing to you but that is just the nature of the thing. In short, I'd bet you have a bad belt or tire that needs replacing. I hope this helps. Good luck.
Posted on Jan 25, 2007
Vcr/tv how to get the carriage unstuck
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Nov 15, 2015 | Televison & Video
Reassembled my componet stereo but don't get sound from Tuner or Casset Tape Deck
It could be a bad interconnecting cable OR the fact that the connector inside the unit has broken solder joints. That is why these types of units that I have worked on often have many problem in that the wave soldering used in manufacturing is not made for a lot of abuse or thermal cycling. The problem can be solder by getting into the unit and applying the correct amount of solder onto the connector using good old Kester 44 not the cheap other stuff.
Dec 22, 2012 | Audio Players & Recorders
2000 Buick Century. Put in a replacement radio/cd/casset player. Radio works, clock works, but CD and casset do not. The message comes up E 13. What does this e code mean?
if its a radio shack radio, it means E13 means "Tape Communication Error". It is caused by the
microprocessor reading speed pulses from the tape deck either too fast, most other makes mean about the same thing, normally a stuck tape will cause this code to show up, either that or the drive gear that loads and unloads the tape is broken, cracked, or jammed
Sep 26, 2011 | 2000 Buick Century
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
Hi, when I put a cassete in my tape deck TD-W315 the cassete runs very fast. It looks like a LP in 78 RPM? Does anybody can help me?
Check to see if the capstain roller is pressing against the capstain. Sometimes they get stuck or something has broke preventing it from pressing on the tape.
Sep 08, 2010 | JVC TD-W118 Single Cassette Deck
Tascam234 /casset tape-4 track,
clean the heads, make sure the tape has no edge damage
Feb 02, 2010 | Tascam 2488 Portastudio Multitrack...
VDO casset still in my VDO player
F-03 means mechanizam jam while unloading please contact nearest expert
Jun 09, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Apr 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Cassette tape door won't open - tape inside
your question is confusing.
CD player or Casset tape player?
Jan 22, 2008 | Audio Players & Recorders
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Aiwa Z-L520 Shelf System Logo
135 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
