Question about Uniden BC350 Base Scanner
My BC350A gets stuck on a couple of different frequencies and will not keep on scanning automatically. Whats up?
  • 120 Answers
Those are "birdies" or internally generated signals, you have to lock those frequencies out if they are programmed into the memory, or set your search limits so you do not pass them if its in a seach mode.
Posted on Jan 02, 2009
Radio frequencies bullhead city, az
Best of luck with that Betty. I am surprised US laws allow you to listen to police and emergency bands. In the UK we could get arrested for that and the equipment confiscated.
It all became less interesting when radios were changed to transmit and receive on widely different frequencies and automatically select different channels to find clear air. Going digital further complicated things.
Knowing the frequencies is unlikely to be helpful - you need to know the frequency band(s) allocated to those services and keep scanning them until something is found. I can't help with that other than tell you, you are likely to find the experience less interesting or satisfying than you imagine.
Dec 31, 2016 | Radio Communications
How do i program frequencies into my uniden bearcat scanner bc350a
The BC350C is a factory pre-programmed scanner, so you cannot program it in the standard manner - entering frequencies via the keyboard. You can, however, transfer a displayed frequency from the SCAN or SEARCH mode into the PRIVATE bank. Details for doing this are in the factory manual that you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Jan 09, 2011 | Uniden BC350C Base Scanner
How do i program the bc350a scanner
Your scanner does not have a standard keyboard programming function. Rather you must "capture" a frequency in SCAN or SEARCH mode, and then transfer (program) it into the scanner's PRIVATE bank. For detailed instructions on doing this, you can download/print the scanner's operating manual here:
lhttp://www.uniden.com/pdf/BC350Aom.pdf
Bill B
May 10, 2010 | Uniden BC350C Base Scanner
It will not scan.
I think you are receive a data transmission or it is a frequency associated with some other local source like a satellite dish for example, just lock it out.
Apr 06, 2010 | Uniden BC350 Base Scanner
My uniden bc350a police scanner is not scanning frequencies stops on one and stays
Press manual,adjust the squelch to where it is silent,press scan. hope this helps..
Mar 20, 2010 | Uniden BC350C Base Scanner
Press manual,enter channel number,then press manual,enter the frequency you want,then press E,if you make a mistake,press CLR twice to erase. You can get your frequency, for your town at RadioFreq.com. ....hope this helps...
Mar 17, 2010 | Uniden BC350C Base Scanner
How do you progam a uniden bc350a scanner
If you know the frequency, push the program button,use channel up-down till you see the frequency you want, you may have to flip the switch in the back. You can get frequency,s at RadioFreq.com .....hope this helps...
Mar 14, 2010 | Uniden BC350C Base Scanner
I have this BC350A model and lost the manual on how to program it. where can i get a manual?
It can be obtained from the Uniden Website, or directly downloaded by visiting the link below...
BC350A Manual
Nov 11, 2009 | Uniden BC350C Base Scanner
I have 3 zone valves in my house and even when they are turned off the heater keeps turning on whats going on ?
It could be a couple of different reasons. It is possible that even though the thermostat is not calling the end switch on a zone valve may be stuck. Is there a zone that is warmer than it should be? Another thing, depending on the frequency of the cycling it could be a normal part of operation. (the boiler may maintain a low limit)
Hope this helps
Oct 05, 2009 | Honeywell Heating & Cooling
Police scanner codes
i need help to find free police and fire scanner frequencies
Nov 10, 2008 | Uniden BC350C Base Scanner
Uniden BC350 Base Scanner Logo
138 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
