Question about Panasonic Linear ES 8003 W Electric Shaver
Battery only keeps a charge for about 10 seconds
Even after my panasonic electric razor model ES 8003 is fully charged (at least all of the green lights are lit) it will go dead in about 10 seconds. Do I need a new battery?
    Problem Solver:
  • 14 Answers
Sounds like the switch is dirty and turning off ... take a look at this video and see if you need to clean it. Mine would not charge or run until I cleaned the switch contacts.
http://www.youtube.com/watch?v=9b7lf5hqjag
Posted on Apr 28, 2009
  • drgold2000 Jul 09, 2009
    My model is almost the same as your model ...
    Problem: Model ES7037
    CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
    Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
    Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg
    12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
    Comments:
    Jan 12, 2009
    Could not get the YouTube link above to work so I will paste it below:
    http://www.youtube.com/watch?v=9b7lf5hqj...
    Use that link to disassemble and clean the switch then put it back together.
    All newer Panasonic Wet/Dry Shavers are probably the same.
    Good Luck!
Are electric razors hard to clean?
No usually come with brush or wash under water
Aug 16, 2014 | Panasonic Linear ES 8003 W Electric Shaver
How do i change the battery in panasonic es-rt51 electric shaver
Panasonic ES-RT51 battery problems?
If your razor battery runs down after only a few shaves e.g jumps from 60% to zero Let the razor completely discharge by leaving it switched on until the blades stop moving completely. (This can take over 24 hours so be patient) When they are stop moving recharge the battery and you will find the battery will charge and discharge just like new!
(This may take a couple of discharge cycles). Only charge the battery when it is flat after this and the problem SHOULD not reoccur.
Terence Saunders
Jan 01, 2014 | Electronics - Others
I have a Panasonic ES8023 rechargeable razor and I want to replace the batteries in it. Where can I find replacement batteries?
When my ES8023 razor quit working, I decided to buy and try a Braun Series 3 razor that ultimately I was dissatisfied with. I favor the Panasonic's narrower head. Deciding to replace the Panasonic's batteries, they were very easily removed. Noting they seemed barely larger than AA batteries, I decided to try replacing the OEM Ni-Cd batteries with some NiMH batteries I had. My only real concern was whether the NiMH batteries would charge adequately from the ES8023 charger....they did, which was great news since Ni-Cd batteries are inferior to NiMH.
Adapting the shorter AA NiMH batteries to the shaver was as simple as laying a small hex nut (#10-32 size I think) upon the negative (upper) terminal in the shaver and then inserting the battery. This makes for a tight fit and provides contact for teh negative end of the battery. The positive nub of the battery makes contact to the shaver's positive terminal with no issues.
The original battery has a long pin extending from the positive tip that I think may be to provide a pin that extends through the shaver body for a charging cord to connect to. However, for the induction charger of the ES8023, I didn't think the pin would be needed, and it wasn't. With two NiMH batteries inserted as described and the shaver reassembled, I successfully charged the shaver overnight in the original charger. I believe NiMH batteries typically charge at a higher current draw than NiCd batteries do, so I do expect a longer charging cycle to be required, but I don't anticipate any issues.
Mar 07, 2011 | Panasonic Linear ES 8003 W Electric Shaver
It stops running after 15 seconds or so. Can it be fixed?
If the charging light illuminates when you charge the shaver, almost certainly the batteries need to be replaced. You will find suitable replaceent batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
If this is not something you can do yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
May 07, 2010 | Panasonic Linear ES 8003 W Electric Shaver
ES 8003 needs new battery, new blades ?
You will find foils and cutters for this model at shaveroutlet.com. See links below
http://shaveroutlet.com/panasonic-wes9080p-cutter-blades-p-85.html
http://shaveroutlet.com/panasonic-wes9081p-shaver-foil-p-86.html
Original Panasonic batteries are not available in the market, however, there is a suitable replacement. You will also find this item at shaveroutlet.com. See link below
Apr 03, 2010 | Panasonic Linear ES 8003 W Electric Shaver
Battery charge
you need to change your razors battery.
Mar 23, 2010 | Panasonic ES 8093 Electric Shaver
Shaver will not hold a charge, panasonic es8003
Sounds like the switch is dirty and not lettingit run ... look at this video on how to clean the switch ... mine would not charge or run until I cleaned the on-off switch.
Apr 13, 2009 | Panasonic Linear ES 8003 W Electric Shaver
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Shaver cutting out
Sounds like the switch to me ... all stops when it stops ... no charging and no running ... take a look at this video ...
Sep 12, 2007 | Panasonic Linear ES 8003 W Electric Shaver
Panasonic Linear ES 8003 W Electric Shaver Logo
399 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
