Question about LG LRBN20510WW Bottom Freezer Refrigerator
GE refrigerator motor wheezing
The motor sounds as if it about to shut down. Every so often I have to press the tempurature button to turn it back on. Both sides frezer and fridge are affected. Also the ice maker quit making ice. The fridge is only 2.5 years old. Can anybody help?
  • 26 Answers
Check behind panle where the fan is may be ice defrost the problem area
Posted on Dec 01, 2008
How do I stop the wheezing sound from my Samsung refrigerator?
Check your door gasket for leaks try to identify where the sound is coming from and get back with me
Apr 03, 2017 | Cars & Trucks
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
Dear Sir, I have a GE Refrigerator model GSS25WGPA. My ice dispenser has stopped working and I think it's the motor. I removed the ice tray and auger. With the door open, I turned the light off and...
Sounds
like you may be right on the bad auger motor. You can remove it from the freezer and apply 120 volts to it with a test cord and see if it goes. I have seen some that actually freeze up and start working when they warm up. If you need to replace it, retail cost is about $70. Here is the GE part # WR60X10258
Mar 24, 2015 | GE Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
The refrigerator is constantly making a cyclical howling or wheezing sound. Very annoying and noticeably loud.
Your condebser coils may be dirty, whenever i blow them out(outdoors) its amaxing the garbage they collect in the course of moving air through them., compressor may be tired.
Dec 27, 2010 | GE Profile PSW26P Stainless Steel Side by...
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor motor shuts off but does not turn back on
it sounds like you have a bad temperature control thermostat. the contacts are probably dirty or loaded with carbon. replace it.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Tempurature Goes Up
sounds to me like your thermostat is bad
Jul 10, 2009 | GE Q Series GSS25QGT Side by Side...
Ice maker drive mechanism won't turn
Remove ice bucket and rinse throughly. Hold down door switch an press for ice you should see the drive in the back for the auger turninig if not youll need to find out uif auger motor is getting electricity and/or is operable.
Mar 15, 2009 | GE Profile PSS26NGS Side by Side...
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRBN20510WW Bottom Freezer Refrigerator Logo
282 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
