Question about Bosch Microwave Ovens
How do you change the light on a bosch HMG8622 microwave oven
  • Bosch Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Dec 02, 2008
Bosch HME97 stopped working
Did you check the original fuse for continuity? Do so with an ohm meter if not. Does the display light up? If you take off the cover & look at the control board do you see anything burnt or, smell burn? If so, it will cost about as much for a control panel as it would for a new microwave.
Nov 15, 2013 | Bosch HME9760 Microwave Oven
Microwave shuts off after 22 seconds
Any product that uses electronic parts is subject to failures. That's why warranties exist. Contact Bosch on their webpage to get assistance.
Nov 16, 2017 | Bosch 500 HMB5050 Microwave Oven
The problem is most likely a bad magnetron, "heart of the system" or the inverter board has failed, "if less than 7 years old"
Apr 18, 2012 | Bosch HMT8625GB Microwave Oven
Bosch HMB405 microwave will not heat although timer works and light comes on when started. Please help.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Jun 28, 2010 | Bosch HMB402 Microwave Oven
Bosch hmt9656GB bloybf fuse
how do you change the bulb on a Bosch microwave HMT9656
Oct 05, 2009 | Bosch HMT9656GB Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
321 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
