My tower wont come on - Computers & Internet
  • cochin Mar 14, 2009
    I have had an emachine for 6 years and most of the problems experienced were broadband related until I changed to Orange, no more problems. that is until now .I powered up my computer after a 6 week gap and it started up fine , 30 seconds later it shut down !! Dead.
    Have gone through the normal checks ,fuse, cable etc but no joy, The only thing that indecates that there's life in the tower is a flashing led (green) light on the back panel.Having now read all the
    answers to questions relating to loss of power, I may have the answer . Its the power pack! Anyone else out there think differently?
    Bryman
  • Justin Case
    Justin Case May 11, 2010
    Dear JK4,
    Is it plugged in? Are you sure?
    Has it ever come on?
    Do you actually expect your problem to be solved with with that description? How about some detail? As much as possible.
    You get what you give.
    This isn't a contest to give the fewest syllables, give us something to work with and we're glad to help.
    Scholar:
  • 57 Answers
Have you had an electrical storm lately? Do you use a surge protector? Those can fail, too. How old is the PC? Power supplies can sometimes only last a couple of years. If you've added a lot of drives or a lot of other hardware on it, it could tax the power supply until it fails. Open the side of the tower. As a first test, notice what happens when you hit the power button. Do you see any of your fans start to turn (just a turn or two) and then quit? That's a failed power supply.Remove the power cable before continuing. Then, disconnect the CD's and hard drive power connectors. They are usually white with four big pins on the right side of the drive. Plug in the power cable and try the power button. If it starts up, you've maxed your power supply and need to upgrade to a larger one.
Posted on Dec 01, 2008
  • 69 Answers
Can you be more specific.. as what you mean by your tower won't come up?... do you mean that it won't power up? if so than and if you haven't checked the power cable, please do so and if the power cable and the fuse are good than please tell me what execatly happened when you last used your tower.
Thank you, I look forward in hearing from you.
Philip
  • Rebecca Mills Oct 31, 2011
    mines done exact the same thing it just went off and it wont power up at all. no LED lights come on and ive checked the power cable and changed the fuse but theres still no life in the tower what can i do?
    doesnt matter no more its just started smoking
Red light on my tower and it wont work
The red LED indicates that the hard disk is active. Replace hard disk.
Oct 19, 2013 | Acer Aspire™ T180 PC Desktop
My tower 200 wont move up or down.
What? Do you have a problem? What is the make and model? What is the problem?
Sep 06, 2013 | Computers & Internet
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
1999 dodge wont start in wet weather. cranks but
Absolutely...
To prove it when you have it running use a spray bottle and spray around the wires starting at the distributor and lastly spray the coil tower. do this late at night then you can see the sparks and see why it is so affected by wet situations.
The failure is a crack in the coil tower.
RECOMENTADTIONs listed below:
1. Replace coil.
2. Use a old oil wire and cut away the wire insulator and slide under the existing coil wire all the way to the base.
3. Use black electrical tape and neatly wrap the coil tower.
Hope this tip helps to solve this problem
R/
David
Apr 07, 2010 | Dodge Ram Pickup 1500 Cars & Trucks
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Tower wont stay running
Are there any beeps?
Could be the power supply going, motherboard, memory or CPU.
Check that all of the cards are seated correctly and tight.
Feb 06, 2009 | HP Pavilion a420n PC Desktop
Tower wont power up
Check the switch which is putted on the outside of your SMPS. Check the switch/ I think the power connector is loose. Check it.
Feb 10, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
