Question about Sony BRAVIA KDL-40V3000 Television
Screen too big for mitsubishi black diamond tv
Cant read subtitles or scores on matches. screen appears to big. The format button to change to the different screen sizes, eg widescreen, etc, does not make a difference. The model is BD53251WS same thing, but for a Sony Bravia KDL 40v3000
It was actually a problem with the satellite feed, not the TV. Dish Network was zoomed in, hitting the asterisk button on the dish remote fixed the problem.
Posted on Dec 01, 2008
Dont have a remote and can't hide the subtitles
Ms. Padilla, you need to enter the menu settings in your television, should be a menu button on you tv set. Once in menu go to picture or scroll through the menus untill you find caption, once you locate that you can turn the subtitles off.
Aug 23, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a mitsubishi medallion and I had digital cable hooked up and the tv is set on 1080i and i can't use the format button to change the screen so I can see everything. Can I switch it off of 1080 so I...
Hi
Check for a button on the remote called Format or Aspect, this should change screen sizes for you. Also if you are using a cable box check its remote for the same buttons it also has format or aspect on it which will change screen ratio. If you have a HD cable box then more then likely the cable boxs remote is the one causing you this headace. You may be in zoom mode check you user manual for the TV on picture formats.
May 01, 2011 | Televison & Video
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
VS 7071
Do a hard reset or factory reset and it should work again
Dec 15, 2017 | Mitsubishi VS-70707 70" Rear Projection...
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Sony BRAVIA KDL-40V3000 Television Logo
336 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
