Question about True T-49 Side by Side Refrigerator Commercial
True T-49 Refrigerator door spring
I need the instructions to change subject spring.
Thank You,
Ron Jones
  • Farley Redfield
    Farley Redfield May 11, 2010
    Does this have a round spindle at the bottom with a plastic cam or a metal roller with little holes in it or something else different?
  • Kent Guidry
    Kent Guidry May 11, 2010
    Can you elaborate more on the spring?
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: True TS-49 Refrigerator freezing food
is it still freezing up? probably your defrost timer or defrost thermostat is going a little bad.
Posted on Apr 20, 2008
refritech08
  • 149 Answers
SOURCE: RE: true T-49
check the hinge position it's probably off line
Posted on Aug 02, 2008
kentguidry
  • 51 Answers
SOURCE: Is the True T-49 prone to problems?
I believe you will be fine if you purchase any True, Trawselson, Delfield, or Hobart reach it. These are all name brand and I have seen them last for years.
Posted on Feb 17, 2009
kentguidry
  • 51 Answers
SOURCE: True t-49 refrigerator
Yes it can. You would have to call a service company to recover the refrigerant, remove the oil in the compressor. They would then replace the oil as well as the refrigerant. The metering device would also need to be changed, along with the thermostat.
Posted on Feb 20, 2009
How do I repair the door spring?
I believe you need to buy and install new door hinges.
Apr 21, 2015 | True T-49 Side by Side Refrigerator...
Seal Gaskets
Generally if you are using the factory seals you never have a problem unless you've damaged the retainer that holds the dart. After market gaskets wont work as well it has to do with the magnet strength, thickness, etc. call True in St Louis if you have to, to get the supplier. Good luck, hope this helped.
Apr 07, 2014 | True T-49 Side by Side Refrigerator...
Seperating Gaskets
Call True in St. Louis and get a name of a supplier that carries factory parts. After market just doesn't work as well as you've noticed. Hope this helps and good luck.
One of the doors will not close
The top hinge has a spring to close door. You can see a pin in a hole on top against a stop pin. Removing pin and winding up the hinge spring helps, find an Allen wrench that fits the other holes to assist. If winding one direction makes worse go the other direction. A new hinge may be in order. I can get you one if you need it. Wmontg5988@yahoo.com
Oct 27, 2013 | True T-49 Side by Side Refrigerator...
How to replace door spring T-49
very easy unless the old spring is blocked /or stopped for the foam insulation , you have to take both hinges and than with needle nose plplies pull it out , unless the FOAM STOPPED IT , than use different approuch you have to take the pannel off and cut around the spring . good luck,
Jul 19, 2012 | True T-49 Side by Side Refrigerator...
Hi there, We have 2 T-49 refrigaretors , but
Whoever sold you the refrigerators should have a parts department where they can order certain parts for any unit. If they don't have it or can't get it, I've found that partstown.com has pretty much every part for True refrigeration that is still being manufactured.
Mar 26, 2010 | True Reach-In T-49-2-G-2 Commercial...
The light bulb burnt out. It is located in the center of the fridge between the two doors. I'm not sure how to remove the bulb in order to replace it.
Unplug the cooler to avoid a shock. Try pulling bulb up and then out from bottom. The bulb should be resting in spring loaded receptacles.
Nov 13, 2009 | True GDM-49-RC Refrigerator
T-49 Freezer Lock
thanks for the question yes on both doors but nowhere else thanks the appliance doc
Sep 03, 2008 | True T-49 Side by Side Refrigerator...
Aug 17, 2008 | True T-49 Side by Side Refrigerator...
RE: true T-49
Jul 22, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
522 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
