Question about Philips 19PS50S 19" TV
Hi -I have a Philip 19PS50S TV and I cannot figure out how change the input from regular tv to the front or rear input jacks. I hooked up SONY PS 2 console and can switch the input on the TV. I do not see an input button on the remote. Please shed some light on this. Thanks Tony
Turn to channel 2, push the channel down button 'till you get to either FRONT or AV
Posted on Jan 05, 2009
Can you hook up a DVD player to this TV? It is a DTQ 13V5FC purchased in 2003.
I took a look at the specs for this set, and it has both front- and rear-panel audio and video input jacks. There's a button marked "VIDEO" on the remote that switches to the AV input so you can watch what you have connected. So yes, you can hook up a DVD player, but there are some limitations.
This isn't a stereo TV, so you'll need a Y-adapter (like this one from Radio Shack) to combine the right and left channel sound from the DVD player into a single mono input for the TV. This means you'll lose any stereo effects from the DVD. Also, even though there are two sets of AV input jacks, the TV can only use one at a time. You can't select the front or rear input separately.
Hope this helps. Thanks for using Fixya!
Mar 26, 2011 | Daewoo DTQ-13V1FC TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I have a 5.1 speaker setup. i have a 5.1 sony dvd amp. a ps3 and a old toshiba tv. ( the one with the orange white red plug in the back. i wanna hook up 3 speakers for front and the subwofer. how do i do...
So, you don't want to use the TV speakers, right? Hook your PS3 audio output RCA jacks to the input on the amplifier and hook the PS3 video cabe to the yellow (orange) video input of the TV. Then hook your speakers to the front or rear outputs of the amp and the sub to the sub output of the amp. If you want to use your TV speakers, you can connect them to the front or back output of the amp for a 4.1 setup. OK?
Dec 09, 2010 | Toshiba Toahiba Satellite A60 A65 Series...
How do I connect a sony vcr plus to my tv?
Does your TV have a ( Red, White and Yellow) jacks in the back or front if it does great they are called RCA jacks. On your VCR locate the RCA jacks. Find the input this is where you hook the cable etc... Find the out puts on the VCR they go to the TV. ON the TV find the RCA jacks find the inputs this is where the cables go. Turn on your TV and find the input channel it maybe AV1, or video1 etc...
Sep 02, 2009 | Sony Televison & Video
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Feb 06, 2009 | Coby DVD-988 Theater System
I have a mitsubsihi ws-65907 and hooed up a sony blue-ray dvd player, I can only get a 480i resolution, is there a way to change it to 1080i?
Make sure the cables from the blue ray player are hooked up to the right 1080 high def input jacks on the back of the TV. There is two different sections, one for regular 480 inputs and another for the 1080i....
Dec 26, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Front Audio Video inputs not working
What model TV is it?
it may be you need to change the input to video 1 or video 2 to get those front jacks to work. if there is a TV/Video button on the front you should be set. If not you may need the remote control. Sometimes changing the channel to below channel 1 will give you that option.
Nov 20, 2008 | Televison & Video
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Philips 19PS50S 19" TV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
