Panasonic KX-P4410 Error Code U30
Have a Panasonic Laser Printer model KX-P4410 which has a error code U30 the door is closed but the error remains, any idead? Do you know where the contact point is?
2 Suggested Answers
SOURCE: I have an old Panasonic KX-P4410 laser printer
i have one you can have.
Posted on Feb 15, 2010
  • 1700 Answers
SOURCE: my panasonic KX-MB772 CX laser
Hi Try unplugging it for 30minutes. and then update the software. Good luck.
Posted on Jun 20, 2011
What is the code 43 in a panasonic KX-FL511
Your error 43 refers to the fact that the fax you are calling does not answer. Talk to them and ask if their fax is set to "Auto Receive". its probably not.
Dec 01, 2016 | Panasonic KX-FL511 Plain Paper Laser Fax
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
What is Error 32 on a panasonic KX-P8000 / 8420.
Error 32 on Panasonic KX-8000 / 8420 is ALSO a "Memory Error". Try to power cycle the multi-function printer by turning it off, disconnecting the power cable from the wall socket and leave it disconnected for 10 minutes. Then plug it back in and turn it ON.
If the same problem occur, then you need to contact the manufacturer for service. It the problem remains after the power cycle, it means that it has a deeper problem.
Thank you and good luck!
Nov 06, 2010 | Panasonic KX-P8420 Laser Printer
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website: http://panasonic.net/pcc/products/printer/windows_compliance/windows_xp_sp2.html
Ron
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
WHEN I TRY TO USE MY REMOTE CONTROL ON MY PANASONIC VCR/DVD COMBO MODEL #DMR ES35V, THE DISPLAY SHOWS U30 1 AND WON'T WORK THE VCR/DVD. CAN YOU HELP ME?
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Oct 11, 2008 | Panasonic DMR-ES35VS
Error code 061 and the ADF door is closed
In this case make sure that the plastic tab that actuates the sensor is not broken off. If it is, try and find some way to defeat it. Other wise you will have to replace the whole transmit door assembly.
Apr 29, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Copier giving error
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
Sep 06, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
59 people viewed this question
k24674
