Power supply fried. laptop been without pwr for couple days
My laptop power supply went bad and my laptop was without power for 4 days. When I replaced the pwr supply today its telling me my profile didn't load correctly and set me up with a temporary one. How do I get my old profile back and how much data did I lose permanently? (pics, music, etc...)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
You still have that one but it is running in safe mode.
what you need to kow is that the power supply may have damaged your harddisk. if so unlikly to be fixed.
not much hope.
Posted on Dec 01, 2008
TURNS OFF ITSELF
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 24, 2012 | RCA HD52W59 HDTV Projection Television
New motherboard will not power up. Power supply OK, No manuals or CD. Need pinout and label on Motherboard for motherboard to case connections for an ACER ECS EG31m V.1.0
[1 2 3 4 5 6 7]
[8 9 10 11 12 13 14]
[Orange White NU NU NU NU NU]
[Green White Blue White NU NH Green Orange]
NU = Not used/No wire
NH = No hole
1-2 HD
8-9 PWR LED
10-11 PWR SW
13-14 LAN
May 24, 2012 | Acer Computers & Internet
Laptop wont power on
Could be a power supply problem,,,,,dc connector oir mother board. also bad battery may cause it to not power up. Remove battery...if it still does not power on....unplug pwr supply from computer and see if the light on the supply is on if so try to re-plug cable in watching the light on pwr supply...if it stays on problem is the switch or motherboard. if it goes out problem is the motherboard or something loading it down
Hope this helpsTom
Sep 02, 2011 | Acer Extensa 5630-6806 Notebook
Connected 20V laptop power supply to 1touch4 by accident. Now with its own 12v pwr supply connected, it just flashes and HD does not spin up. Pulled it apart and nothing obviously fried. Any suggestions?
The electronics has been damaged and the cost of repair may be high even if you can find an electronic repairer.
I suggest you put your money towards a new USB hard drive as 1Tb hard drives are less than $100.
Apr 25, 2011 | Maxtor OneTouch 4 Plus 500GB External USB...
My HP media center desk top will not turn on. I have checked power and switched main plug. My son recently cleaned out the dust and showed me where to plug more power to speed the machine up. Which I...
make sure that this machine does not have switch on the pwr supply on back of pc.some times it is hard to see it. make sure there is pwr to the outlet and try different outlet. do you see any lights on back or front of pc. if not means no pwr is coming to pwr supply.
Dec 12, 2009 | Computers & Internet
My wife has a toshiba satellite L35-S2151 laptop. When she went to turn it on, the orange battery light flashes 8 times and nothing else happens. Any clue as to what is going on?
Try turning on the device with the power connected if it turns on, keep the power plugged in for the entire day. See if you will have the same problem without the power supply. If it still occurs without the power supply, you may have a bad battery, you can verify if you can get swap battery from a similar laptop.
Oct 01, 2009 | Toshiba Satellite L35-S2366 Notebook
Dell Inspiron 630m does not do anything.
Jimmy check the power supply adapter, if there is a light on it, it is ok, check for the memory, take it out and clean the contacts using a pencil eraser, reinstall them and try,.
Jul 20, 2009 | Dell Inspiron 630M Notebook
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
Dell 5100 won't come up after memory swap
Did you make sure that the power supply was off and or discontected from power source before opening the case?
It is possible that you have fried something by having a static discharge either from you hands or the vacume cleaner hose. Have you checked the correct installation of the memory make sure you are putting the original memory in dimm1 and dimm2.
Also check that the power button is still connected to the mother board just follow the wire from the back of the button just to be sure. Also check that the power switch on th power supply is on.
Link is to manual
http://support.dell.com/support/edocs/systems/dim5100/en/om/T8144bk2.pdf
Jan 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
