Question about Insignia Portable CD Player with Skip Protection
I have an Insignia CD and MP3 player that skips. I wasn't sure if I can adjust the laser or not. I tried cleaning the CDs and lens.
SOURCE: insignia video 2gb mp3 player wont go to menu
check on the setting display you might have it one 1hr shut off..you can easily switch it to off for then your mp3 won't shut off..
Posted on Jul 26, 2007
SOURCE: Transferring music to Insignia MP3 player
When using your media player... you need to first figure out if you are using windows media player 9 or windows media player 10. Also what windows are you using on your computer, that makes a difference as well... Make sure you have the mp3 player plugged in properly and then...Once you are in your windows media player go to your lib tab... soon as you are in there then on the right side there should be section on where you could build a lib list. Meaning you should be able to pick the songs in your lib and just drag them over. On the bottom you should see something that says sync... Once you've choose your songs and dragged them over... all you should have to do is press the sync button and it will do all the work for you from there. And it should let you know when its complete...mine does. Hope I could help you.
Posted on Sep 13, 2007
DaveOgle
  • 8 Answers
SOURCE: insignia 4gb / video mp3 player
You'll need to erase the internal and external memory, then re-add all your files.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Posted on Feb 24, 2008
SOURCE: INSIGNIA MP3 PLAYER
I had this problem also and I think I figured it out because now my music will play. I took the songs I had from limewire, highlighted them all and clicked "save as", opened it with windows media player and on wmp I took my playlist and named it on there....first I synched the songs under "sync" and they would upload on my player but they would NOT play. I got the same stupid error message. So after they were uploaded onto my mp3 player, i dragged all of the songs onto the right side to make a sync list AGAIN and clicked start sync, all of the files said "already on device" so I kind of got mad thinking it still didn't work...when I unplugged it and tried to play the song, they ACTUALLY PLAYED. I fought with this for so long and contemplated about throwing the stupid thing down the toilet but for whatever reason, synching it in two different ways in that order, it worked and it stopped saying "error:can't open this file"...hope this works for you and anyone else having this problem because I know how frustrating this got for me. hope this helps. Good luck!!!
Posted on Sep 16, 2008
shahabdun
  • 249 Answers
SOURCE: I have an Insignia Portable CD Player with Skip
Lens is damaged.
Posted on Jul 06, 2009
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
Nov 27, 2017 | Coby Lands Phones
Hyundai i30 cd player
hi Squeakylyssa .This goes for all cd players.
If a CD is skipping, first ensure that the disc is working properly by checking to see if it plays on another device. If so, you'll have to uncover the problem in your CD player. Some common problems include: broken parts in the device, physical damage to the CD player, dirt within the player or, most commonly, damage to the lens.
Before you do anything with the CD player, it is important to remove the batteries and disconnect the device from any power source. Wait half an hour before you begin cleaning the device.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. Place a small amount of your cleansing solution on a cotton swab or other applicator that came with a lens cleaning kit; as an alternative to lens cleaner, you can also use isopropyl alcohol. Rub the cotton swab in very light and small circles against the lens until it is clear. Allow the lens to dry, and then proceed to test the CD player. If the CD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.
A CD player has a few hardware components that may be causing your discs to skip. Unscrew and open the case of the CD player to locate the read head and potentiometer. Depending on the type of device you have, you may need to remove the bottom cover to gain access to the soldered side of the electronics board - if so, you will need to remove the whole board before you can proceed. In single-play designs, you should be able to find 3 or 4 screws that need to be removed to enable you to take out the whole optical deck. There may also be a grounding contact under the deck held in with one screw. Make sure you replace this exactly as you found it.
If your player spins for some time without finding the list of tracks and keeps returning some kind of error message once you place a CD in the player, there is a most likely a problem with the read head. The read head is represented by a small square piece that has a plastic disc sitting on top of it. Using a flathead screwdriver, adjust the plastic disc to realign the read head. This process requires you to plug in the device and hit play and stop until these adjustments fix the CD player. Make sure to put the case back on the CD player each time you test it to avoid any electrical shocks.
The potentiometer, which is positioned directly above the laser, may also be misaligned. Usually this is represented by a small square piece that has a plastic disk on top. The disk has a slot adjustable using a small flat head screwdriver. Before making any adjustments, mark the current position of the potentiometer using an indelible marker pen so that it can be returned to its initial position if need arises. You will need to gently adjust the potentiometer and locate the position where the CD player recognizes the disk again and plays it without skipping. Since this is more of a trial and error process, small rotations of plus/minus 30 degrees of rotation are usually recommendable. For safety, put the case back on the CD player each time you test. If you are happy with the performance after the adjustment then put the case back on and you are ready to rock.
Dec 14, 2017 | Cars & Trucks
Skips and doesn't play CDs
I'm guessing this is a CD player?
Try to open the lid and with your finger (without touching the laser lens) move the lens toward the outside edge. Sometimes the gears that move the laser skip and this will re-set it. If not try cleaning the lens with an alcohol cleaner.
Oct 16, 2012 | Audio Players & Recorders
My cd player skips
there are a few options
maybe your cd player is on an unstable surface and so the cd skips from vibrations or movements so you will need to put it on a stable surface free from movement or rumbles so that the cd player can read the cds without any interference.
Also maybe your lens is dirty or your cds are dirty or scratched, in which case her's what you can try:
1) buy a cd lens cleaning kit from a music shop or electronics store and clean the lens
2) but if the cd player is quite old then there may be a build up of dust and dirt inside so you will need to get it cleaned professionally
If the cds are dirty then clean using a soft cloth from the inside to the outside edge in a straight line
if the cds are scratched then buy new cds and treat them with respect. Make sure you don't put grubby fingers on the surface and try to handle them by just putting your finger through the middle hole and the outside edge with clean hands. and remember to put them back in the case and not leave them on the side or on the floor or stacked in piles
good luck
Jan 07, 2011 | Bose 901 CD Player
My Insignia CD player says there's no disc when there is.
Try a lens cleaner. Also, ensure that your disks are clean. If you're playing CD-Rs, make sure that the disks have been finalized properly. If the problem persists, you may carry the unit in to the place of purchase to pursue service options.
Mar 16, 2010 | Insignia NS-DV2G MP3 Player
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Jan 06, 2006 | Aiwa XR-MS5 CD Shelf System
Insignia Portable CD Player with Skip Protection Logo
26 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
