Question about Pride Mobility Products Jazzy 1170 XL Plus
Jazzy wheelchair 1170....left side stops and sticks,.
I go in circles until someone comes and wiggles the electrical cords in the back of the chair and then there is a big **** and it goes for a bit, and then it happens again. Someon said maybe it is the brake sticking, but why does it **** and go when somone wiggles the power cords in the back? When it stops.it also blinks 1 or 2 red lights in the control.the whol control doesn light up like it should when it is running right. Plz help me.I am sick of being stranded and scared. Renee
  • Robin Apr 29, 2009
    I have a Jazzy 1170 XL, and it is doing some things that I don't want it to do. Sometimes the lights on the control will blink and not come on all the way. When this happens the wheelchair will only go in circles until it breaks loose. Can anyone tell me what is causing this? It just started doing this last week, but it does it at some point every time I use the wheelchair now.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Posted on Mar 31, 2009
  • 32 Answers
Those codes 1 light flashing and 2 lights flashing refer to a left and right motor fault respectively....expensive repair
Posted on Apr 03, 2009
Omg your so funny.
Posted on Jan 02, 2009
  • 4 Answers
Read your owners manual or down load one from Jazzy
Posted on May 17, 2009
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Jazzy 1170 Powerchair
Just wrap your wrist with an Ace bandage. LOL
Sep 27, 2017 | Pride Mobility Products Jazzy 1170 XL Plus
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I have a Jazzy 1101 that is showing is showing a right motor disconnect code (3 Red & 1 Yellow) I have checked all connections on the chair and have not found any to be loose or corroded. Several times...
Hi. Sounds like a stuck or worn brush in the right hand motor. If one or both of the brushs are sticking, give it a light file on the sides of the brush until it slides in and out smoothly. Be carefull tightening the brush caps, as they can crack if tightened too hard, but they do need to be done up firm. Good luck. Neil.
Jul 16, 2010 | Electric Jazzy 1115 Power Wheelchair
Lights Flashing Right to Left and will not turn off
That should have unlocked the controller. You might try disconnecting the power to the chair and then reconnect and try again. Start with just the joystick plug-in in the rear, and then try the main battery harness unplug.
May 22, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
441 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
