Question about Motorola Talkabout T5620 (7 Channels) 2-Way Radio
Moto T5620 Buzz
I have two Moto T5620. One of them makes a buzz when i push the others PTT button, and nothing can be heard. Is there any way to repair it?
  • 123 Answers
Check if that radio has the QT feature eneable, be sure that you are not making any feedback when you press the ptt. If one of the radios could have a problem be sure if the Buzz is transmited or received for the radios
Posted on Jan 25, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Remote will not work have change battery
You may need to program it. Here is how you do that, if that is not a fix then you may need a new remote.
  1. Remove key from ignition.
  2. Close all doors.
  3. Open driver side door and leave open.
  4. Perform the following steps within 24 seconds.
    a. Insert key in ignition.
    b. Turn key to ON and OFF.
    c. Repeat step b two more times.
    d. Remove key.
    e. Push driver door frame button three times (black rubber button located on driver door frame that tell the vehicle whether or not door is closed.)
5. Buzz sound, chime or doors will lock and unlock should be heard at this point signaling that the vehicle is now in
programming mode. If not, wait 40 seconds and return to step 4.
6. All transmitters need to be programmed at this time, including the old ones. Push any button on the transmitter
two times. A buzz sound, chime or doors locking and unlocking should be heard at this point signaling that the
vehicle has accepted the new transmitter code. If there is only one transmitter, repeat this step two more times
using the only transmitter. If there are two transmitters, repeat this step two more times using the second
transmitter.
7. Push driver door frame button one time. Two buzz sounds, chimes or doors locking and unlocking 2 times should
be heard at this point signaling successful programming.
Sep 20, 2012 | 2003 Mazda MPV
How can I get the player remotes to connect to the xbox360?
First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the connect button on the 360 controller so the lights around the big X are spinning around. Finally, push the connect button on the 360( which is located directly to the right of memory unit B) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller, and you will know its connected because one single light on the controller will remain lit while the others wont.
Sep 10, 2012 | Microsoft Video Game Consoles & Games
FCC ID: K7GFV300 one of the radios doesn't output sound, or the other one doesnt transmit it. i can hear the little buzz when you press the PTT button
Check your programming first to see if the radios match perfectly. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/FV300%2001-11-08.pdf
Next, check the battery pack in the radio that is not transmitting. A low or bad battery can prevent a radio from transmitting, as it takes more power to transmit than to receive.
Lastly, check the mic hole to see if it is covered or has debris.
Best regards.
Oct 12, 2010 | Motorola Walkie Talkie 2-Way Radio
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
Dryer drum will not turn.
Hello.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
Jul 22, 2009 | Kenmore 94052 Dryer
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
Feb 06, 2009 | Quinny Buzz Jogger
Turning Quinny Buzz 3 into buzz 4
Hi I have just seen this on ebay it was £50 ish hope this helps
Feb 05, 2009 | Quinny Buzz Jogger
One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Motorola Talkabout T5620 (7 Channels) 2-Way Radio Logo
186 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
