Question about Microsoft Xbox 360 Console
1 red light on my xbox 360
It does have black screen and white writting but it says E 74
ilragatzzo78
  • 241 Answers
SOURCE: e74 and 4 red ring Xbox 360
the a/v card is faulty, there is a chip called " ana or hana " and that goes bad.
the best solution is either to send it to microsoft " they will charge you around $ 100 - $ 150.- " to fix it, or to find the chip and replace it.
there is hope though try another a/v cabel, borrow one or something, your cable may be damaged. if the new cable doesn't work then " 100 % sure is the chip " is very common problem.
i have one with that issues and bought another 360 " broken " and i am going to try to switch a/v cards.
Posted on May 25, 2008
SOURCE: i need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
Posted on Dec 29, 2008
SOURCE: I have two broken 360's, one that randomly freezes and one with the one red light and E 74 error. I need help fixing the scaler chip
I'll buy them from you.
Posted on May 29, 2009
rsheehan
  • 69 Answers
SOURCE: Error E 74 on my Xbox 360
Lol just did one an hour ago One red bottom rignt
Run smooth cool all green Now ITS THE X CLAMP !!!
Mod it or find someone who knows how.
Posted on Jun 22, 2009
repairtech99
  • 767 Answers
SOURCE: xbox 360 has one red light on and shows error e 74
4 red light is a defective A/V cable.
E74 ,E69, no picture , white lines..... the list goes on
99.99% of the problem is the G.P.U. over and de-solder itself
from the main P.C. board. The solution is to have a repair shop
re-soldered (re-flowe) the G.P.U. back to the board and your
problems become a distant memory . That's the truth .
I hope that help a little
Rob
Posted on Sep 22, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Hi, i have problem E 74 one red light ..... would
E74 is due to an inherent engineering flaw and will continue on new consoles until Microsoft institutes a revision.
E 74, E 79, E 71 is shown on screen and a solution to fix it is by ensuring that your A/V connections on your Xbox 360 is secured. Another possible cause to the error is that there is a power surge or outage on your system.
BETTER U Click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 Elite Console
It's got 1 flashing red light and it says E 74 (xbox 360)
you need to have the x-clamp replacement done. or if it is still under warranty send it back to microsoft.
May 31, 2010 | Microsoft Xbox 360 Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
Turned on xbox 360 got a black screen saying system error and E 74 at the bottom of the screen and theres 1 red light on bottom right of power button
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Mar 06, 2009 | Microsoft Xbox 360 Console
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
I have one red ring on my xbox 360 and it won't start it goes to a black scren with a bunch of writting
do you have hard drive connected? 1 red light usually means a hrad drive failure. remove the hard drive and reboot
Jun 26, 2008 | Video Game Consoles & Games
E 74
hi reza,
Alot of people have this same problem,
E74 is an error prompt when the xbox goes into safe mode.
Te reasons for going into safemode is buntiful.
The best answer is from overheating.
Try resetting the xbox[little white button]
Good luck
Dec 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
