Question about Singer Quantum XL-1000 Computerized Sewing Machine
Embroidery thread breaks after about three stitches
When trying to embroider, the thread wants to break after about the first few stitches. I have cleaned AGAIN the bobbin area for any little lint and there is none. I have tried to blow anything in the threading area, but it all seems to be to no avail. Can anyone help me with this? I am using the Sulky thread. I have done this numerous times before but the last few times the thread just wants to keep breaking no matter how many times I try. Thank you for your help.
  • sewnice838 Feb 19, 2009
    I have done all of the things that each of you have suggested and still to no avail. I finally took it in to have it checked. Was charged a big amount and was able to use it for not even an hour and the same thing started happening again when I tried to use it again yesterday. So once again I have done all the things that I had done before and it will go back to the dealer in the morning to see if they can find the solution. Thank you all for trying to help me. Wish I could say "Yeah, everything is great." But right now we still need to work on it.
  • Cherri1513 Feb 26, 2009
    I have the same problem! Only mine is w/ the Singer Quantum XL-1000. I have taken it back to the shop twice w/ this problem. They "clean" it out & readjust the tension, "fixed" the cutter (which wasn't broken). Now the threader doesn't work & looks like I'll have to travel the 300 miles (150 miles each way) BACK to the Singer shop. I actually got it to work for almost 20 minutes after I got it home. I was trying to sew a straight line & the thread keeps breaking or gumming up under the bobbin. Does anyone else have this problem? Does anyone know how to fix it?
Hey Sewnice838, when my Quantum 1000 was giving me this problem the gal at the Singer store told me I had to use embroidery bobbin thread as well as embroidery top thread and I had to use a special kind of stabilizer. I also slide the speed regulator to a slower setting so that my machine doesn't get quite so ramped up. Sorry it's such a hassle, but that is what fixed the problem for me. Changing the needle is a good idea too.
Posted on Feb 10, 2009
I had the same problem....I tried cleaning it just like you did. Eventually, I changed the needle and it took care of the problem :)
Hope that helps!
Posted on Dec 29, 2008
How can I get my janome 11000 to work when embroidering? The bottom thread doesn't even show and top thread is always breaking.
The tension(s) may be too tight and could be threaded incorrectly. Start out with a brand new needle. Be sure to RAISE the presser foot when threading the upper thread. Consult the owner's manual to be sure it is threaded in the proper order. Test your stitch on a straight stitch and adjust it so both threads meet in the middle of the fabric. This setting works for straight stitch. However, usually the upper thread tension is loosened a bit for embroidery so the bottom thread will not show on the top of the fabric. Test it on some small embroidery patterns first until it's where you want it.
Mar 05, 2016 | Janome Sewing Machines
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
I have a Futura XL-400 and when I am embroidering it keeps breaking the thread at the needle area. I hear a noise which sounds like its coming from the bobbin arean then the thread breaks and its also
try these suggestions
change the needle
check the needle plate for burrs
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 11, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
I live in South Africa and have a Brother Innovis 90E embroidery machine. I have a problem with the tension in that the top thread loops at the bottom of the picture I am embroidering. In addition, the...
Lauren, were you able to solve your problem. I have the exact same machine and am experiencing the same problems that you state.
Kind regards,
Chantell
Aug 15, 2010 | Brother Sewing Machines
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
Singer Quantum XL-1000 Computerized Sewing Machine Logo
212 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
