Question about Pioneer VSX-D810S Receiver
No DTS light anymore
I have a Pioneer VSX-810S and when I had my Samsung DVD player sonnected I would get a DTS indicator on the display if the DVD had it. I now hav a Pioneer Bluray DVD and I no longer get the indicator light although I do get sound from the rear center chanel. I have tried connecting audoi via optical and coax with the same results. Does the new player just not send any kind of signal telling the receiverit is in DTS mode?
thanks very much
  • 12 Answers
SOURCE: No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Posted on Oct 06, 2007
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
mlapres
  • 757 Answers
SOURCE: yamaha HTR -6130 DTS?????
First, the sound source must also be in DTS. DTS is typically not the default audio selection on any DVDs that have that format...you'll have to select it.
Posted on May 08, 2009
  • 4 Answers
SOURCE: poineer vsx-810s amplifier
If it flashes AMP_ERR, one of the chipamps is shorted & needs to be replaced.
Posted on Aug 12, 2009
Everytime I use the DTS functions to enable my surround sound, no sound goes to my speakers. I am able to use it only for the standard output with the left and right front speakers. What could be causing...
DTS should be enabled only if your source has a DTS digital audio out connected to the receiver.Mostly only DVD / Bluray players have DTS sound and is outputted through an optical or co-axial port on the back of the player. Its a multichannel digital encryption technology where the signal is sent through one cable and your receiver decodes it into 5.1 or 7.1 channels according to the source.
Apr 22, 2011 | Pioneer VSX-D810S Receiver
VSxD209
Hey there denisr, please take look at the display screen on the unit. If you see MONITOR, indicated in the display, then this is your problem . Simply deactivate via the button on the front of your machine. Hope it helps. Good Luck!
Feb 02, 2008 | Pioneer VSX-D209 Receiver
On my pionneer VSX-820-K the dts light is not comeing on when i watch a movie with dts
You may have tuned in a program that advertizes DTS, but, the local cable company may not send it through their atiquated cable network.
Feb 26, 2011 | Pioneer VSX-819H-K A/V Receiver
I had only static on back speaker of pioneer vsx-d810s. Now I can not get the back speaker to work at all. Tried every step in the manual ten times. Now I can not turn DTS on or off. Monitor only show...
well you must config the surrond back speaker , check in operators manual how you do-it and pag.17 to 19 . please check for When “SB*” is selected in SPEAKERS setting mode,
the SURROUND BACK distance cannot be set.
so if you dont have check this site, who has the manual to help you how to config.
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/VSX-D710S-_E is from 710s, but have 810s also
Jan 08, 2010 | Pioneer VSX-D810S Receiver
Poineer vsx-810s amplifier
Apr 17, 2009 | Pioneer VSX-818V-K Receiver
No sound when using 6 channel analog inputs
2 potential issues, first make sure the dvd player audio menu setup is set correct for 5.1 outputs, not DTS or Dolby Digital bitstream, can be difficult but read the user manual under sound options if possible, second be sure the receiver is set to act as the "amplifier only setting " i.e. DVD 6 channel input, maybe EXT IN , not sure what pioneers mode is, but all you need to follow is the dvd player is outputing 6 channel signal paths, and the receiver is acting as six amps, unless of couse you are using a subwoofer line out.
Jan 25, 2009 | Pioneer VSX-D914 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Oct 05, 2007 | Pioneer VSX-27TX Receiver
Open Questions:
See all Pioneer VSX-D810S Receiver Questions
Pioneer VSX-D810S Receiver Logo
62 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
