Question about Dell Dimension 3000 PC Desktop
TIP MELTED I have a used Kensington universal 120 w ac/dc converter I need to purchase a tip to use on the Dell Inspiron 9300 where can I just buy just a tip?
    Scholar:
  • 57 Answers
I know it's kinda lame, but you might be able to get something from Radio Shack. Something else to try is to look at a universal power supply. Some have interchangeable connectors and one might work. By the way, I saw in a store this weekend there are "generic" laptop power supplies that come with several different tips as well.
Posted on Nov 30, 2008
I have a Kensington universal laptop charger for my Dell Inspiron. I have lost the adapter plug. Can I purchase, just the plug, rather than purchasing a new charger?
WELL AT DELL SERVICE CENTER YOU MAY HAVE TO BUY A NEW COMPLETE CHARGER BUT THAT WILL BE COSTLY INSTEAD YOU CAN MAKE YOUR OWN PLUG .ALL YOU NEED IS JUST A SET OF WIRE AND A THREE PI N PLUG.
Jul 21, 2011 | Computers & Internet
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
I have the targus model APM65US DC auto/air adaptor and various tips. Which tip/connector is compatible with a Dell Inspiron miniu 10. Several look like the right size: #s 102, 104, 206, and 207. Which...
I know this sounds odd but use whichever one is the best fit and works. Also I suggest that you compare them carefully with the original noting differences in length, diameter and construction.
I think you will find that one fits better than the others.If it works and you don't have to push too hard to locate it, and it stays in firmly and connects OK then it will be fine.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Targus APM65US Auto/Airline/AC Adapter -...
Have a dell insprion 9300 Will not charge the battery I have two of these laptops ones the e1705 and the 9300 batterys are the same as watts does the same thing with both batterys it will run on battery...
The jack on the laptop that you plug the AC adapter (Charger) into, is called a DC Power Jack.
http://www.laptopjacks.com/view_part/Dell-Inspiron-9300-Laptop-DC-Power-Jack-DL111500.html
I would like you to click on the photos of the jack. (3 views shown. Has www.laptopjacks.com on it)
The middle photo, and the photo to the right, shows copper prongs that protrude out of the jack.
The view to the right shows the jack upside down, in relation to how it's mounted on the motherboard.
The prongs go through the motherboard, and are soldered to circuit traces on the motherboard.
(For simplification, think of circuit traces as being very thin flat copper wires on the motherboard)
There is data stating that the solder joints have a tendency to crack, even with normal usage of just plugging, and unplugging the AC adapter.
It is also stated that the motherboard area where the DC Power Jack is mounted, is of a bad design.
Many have had the motherboard replaced, ($400 to $500), only to have the same problem come up later.
It has also been stated that the manufacturer states replacing the AC adapter, but has been shown to no avail in solving the problem.
Same thing comes up for the Dell Inspiron e1705.
(I know, I'm just a 'Ray of Sunshine')
A cracked solder joint, or cracked solder joints make an intermittent contact. When the DC Power Jack is in a certain position with the AC adapter plugged in, the contact may be good. Moved around by plugging in the AC adapter again, the position may change, and result in an intermittent contact, or no contact at all.
Result?
Laptop will not power off of the AC adapter, nor will the AC adapter charge the battery.
This is the reason why the laptop will run straight off of the battery, but the battery isn't being charged back up.
It could also be that the damage is further than a cracked solder joint, or cracked solder joints.
One of the prongs could have come loose from it's mounting, and no longer be attached to the pin it's supposed to be attached to.
[ The AC adapter converts AC {Alternating Current} electricity from your household, or business, into DC electricity.
{Direct Current. Batteries are an example of stored DC electricity}
DC uses two connections. A Positive connection, and a Negative connection.
One of the prongs is for the Positive connection, another one is for the Negative connection. The other prongs are used for stability, to mount the DC Power Jack in place to the motherboard. Generally the center pin/s are for a Positive connection, the outer pin/s are for the Negative connection ]
Unless I had the laptop in my hand, I can only give you a generalization of what may be wrong, and the possible solution to repair it.
1) All power to the laptop removed, (AC adapter and Battery), see if you can wiggle the DC Power Jack around. Any perceptible movement is bad.
2) Past this point the laptop will have to be completely disassembled, down to the bare motherboard in your hand. Requires visual inspection of the solder joints for the DC Power Jack, and the surrounding circuit traces.
It may be something as simple as resoldering a cracked solder joint. (Or joints)
It may go further into replacing the DC Power Jack.
It may still go further if the area on the motherboard where the DC Power Jack is mounted, has cracked.
You or a tech may not be able to mount a new DC Power Jack.
This would require a workaround, IF feasible. Won't be aesthetically appealing, however.
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
Dell Support > Inspiron 9300 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Older Dell Inspiron 1300 laptop, but linked to show you more about replacing a DC Power Jack, and the required 'little things'. Such as properly cleaning the solder joint area on the circuit trace, that a prong for the DC Power jack, goes through, and is soldered to.
http://www.insidemylaptop.com/remove-motherboard-repair-dc-power-jack-dell-inspiron-1300-b120-b130-laptop/
You may find this useful also,
http://www.coredatarecovery.com/how-to-repair-a-bad-power-jack-on-a-dell-inspiron-51501100-series-laptop-for-under-2000/
Click on - Dell 5150/1100 series Slideshow
(Author Charles House)
1) Buy an wear an ESD wrist strap. (Electro Static Discharge) The average cost is around $3 to $8.
Connect the alligator clip to a good ground source. I connect to the metal frame of an empty desktop computer case.
Observe Anti-Static Precautions.
[Your body carries static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Wear the ESD wrist strap, and connect it to a good ground when working on the laptop.
Should you leave in the middle of working on your laptop, upon your return be SURE to put the ESD wrist strap back on ]
2) There may be as many as 60 screws, and 12 different types of screws. Do Not mix them up.
Use a multi-compartment container for the screws. Mark each compartment for the area the screws came out of. Do not stack them neatly on a table. Recipe for disaster.
You can use a clean egg container in a pinch. Mark each egg holder.
3) Use Solder Wick, (Desoldering Braid) to remove the old solder. Do not use a Desoldering Tool.
4) Make sure the area of the circuit trace that you have removed solder from is CLEAN. The links above will detail more about this. Make sure the circuit trace areas are pre-tinned with solder, before inserting the DC Power Jack's prongs. Don't worry if the hole in the circuit trace is covered with solder from tinning.
You can heat it up to insert the prong. (One prong at a time)
5) DO NOT linger too long with the soldering iron, (40 to 50 Watt) This can render a circuit trace useless.
It will burn it, (And the motherboard), and render the circuit trace useless from accepting the tinning.
(Solder it applied to the area to be soldered in a light coat. = Tinning)
Linger too long, and you can lift the circuit trace right off of the motherboard.
For further questions please state in a Comment.
Regards,
joecoolvette
Oct 27, 2010 | Dell Inspiron 9300 Notebook
Replacement tips for Kensington 120W AC/DC adapter model 33197
I have the same model adapter for my dell, I believe there is a number on the tip that you need, have you tried ebay for the part they are called 'smart tips'. I think it's a different adapter direct from kensington now, but you can buy them from 3rd parties.
http://us.kensington.com/html/10442.html
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270522811796
Feb 12, 2010 | ACCO Brands Kensington Thin and Light 70w...
Computer dose not charge battery (replaced battery and same problem).. Computer works fine when pluged into DC power pack.. Computer is A Dell Inspiron 9300.
check if you are using correct Watt of ac adapter.if yes then download the latest BIOS update for your laptop. if all fails then replace the motherboard.
Oct 14, 2009 | Dell Inspiron 9300 Notebook
My computer will not recognize the battery. Runs OK on AC.
Since the system is not seeing the batteries the apparent fault is the motherboard connection for the battery. If under warranty , contact Dell, in not, you can try and purchase a replacement motherboard on EBay.
Apr 26, 2009 | Dell Inspiron 9300 PC Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Dell 2200 Inspiron won't power up
Your motherboard is fried, and it probably needs to be replaced. But this is expensive, and you best bet is to just ditch the laptop and buy a new one or another one. Ebay.com has really great deals on laptops, new and used. Also, if you are wanting to buy from a specific company, most companies have outlet stores within them, where they sell laptops that have been built already/refurbished, and the customer had changed their minds about buying them or getting thems ent back. You can get a really great deal by using this purchase option as well.
Sep 06, 2008 | Dell Inspiron 2200 PC Notebook
Dell Dimension 3000 PC Desktop Logo
55 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
