Question about Samsung Televison & Video
My 42 inch samsung dlp tv keeps powering off on it's own. Why???
My tv continuously keeps shutting down by itself. What could be causing this?
Try tightening the screw on the lamp door. on mine the heat of the unit would loosen the contact which would shut the TV down.
Posted on Feb 05, 2010
  • Samsung Master
  • 5,138 Answers
Your Lamp could be going out.they only play for 5,000 hr some 8,000 hours do the math.
Posted on Dec 01, 2008
Samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 12, 2010 | Samsung HLS4266 TV
    My dlp tv keeps switching itself off
    take bulp vent cover off rear of tv. there is a little plastic switch that gets pressed in by this cover. i taped mine in because the cover wasnt pressing it in all the way and causing tv to shut off all the time. havent had a problem since.
    Jan 11, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
    Why is my 42" dlp tv turns itself off after awhile?
    the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
    do it fast
    okay
    Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My 56 inch Samsung DLP keeps shutting off. I have
    Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
    Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung dlp keeps shutting off
    Could be several things but the most common causes are:
    1. Make sure that the lamp is working:
    -make sure it lights up as viewed through the lamp access panel or the back of the set and stays lit. New lamps for most units are available on eBay for less than 100.00 with free shipping.
    or
    2. That the lamp access door safety switch is properly held in place:
    -make sure that the lamp access door is in place and that the screw is snug. The symptoms of a bad / broken or open switch is that the unit will light up and the fans will spin for about 15-20 seconds then the unit will power down.
    Other notes: A general comment on cleaning the fans... that is only part of a heat problem or preventive maintenance. Make sure you also clean the heat syncs of any dust. These are the fin shaped items... some are black and others are silver... found near or behind the fans. Get yourself a one or two inch SOFT bristle paint brush and gently wipe the fins clean with the nozzle of a vacuum cleaner close to the area to **** up the dust. Clean fans won't do much good if these are coated with dust and most of them are after a few months of service.
    I have two 50" units and I clean them every year in the spring... before the heat of the summer hits. Unlike other TV designs, DLP's move a LOT of air so this is important.
    Aug 14, 2009 | Samsung DLP HL-P5663W 56" TV
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Tv shuts itself off
    Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
    Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
    TV TURNS OFF AFTER 20-30 MIN
    May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
    Televison & Video Logo
    492 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
