Question about Belkin F1U115E Parallel Switch
Belkin Parallel AutoSwitch F1U115E
We recently upgraded one of our workstations from Win 2K to XP Pro. Once we did the switch stopped working. Both connected PC's are on XP pro now. When I connect the Com1 port to the PC the printer works fine, however when I try to use the switch with the new PC I get the following: PCL XL Error Subsystem: image Error: Missing Data Operator: ReadImage Position: 12 Except for the PCL XL Error the other 4 fields give a different error message each time. Now the other PC prints without any problem. I have moved the connection from port A to B, same issue. I have tried different cables, same issue. It seems that once the new PC was brought in, the Belkin AutoSwitch stopped working correctly. Is this a known issue?
  • 31 Answers
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of 255.255.255.0 and the ip address of the gateway. Please respond with any further.
Posted on Jun 06, 2007
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
Dual op systems
in bios setup usually under security you can remove user passwords.
you get into safemode for 2000 and in control panel and remove it form users administrator account
If your not interested in to os systems then you can format
Mar 06, 2009 | Compaq Armada 3500 Notebook
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
On my pc running win xp pack2 i want to install win 2000 pro. how can i do it? please suggest me.
You can either run a dual-boot system where you can boot into XP and Pro when you start your computer, or reformat and install 2k.
If you want to dual-boot you would need a blank partition on which to install it. Unfortunately if you do not already have more than one partition on your current drive, it would be difficult to split a single partition drive into adding another partition unless you are familiar with the tools required to perform such an operation.
However, if you only need to install 2k without having access to XP, all you need to do is insert the Win 2k disk and follow the installation wizard. When it comes to selecting where to install, it should show a partition containing winXP, which you can then install 2K to. Remember, all files on your XP install, including the operating system itself, will be removed. You would lose everything on that partition. If it is a single partition drive, anything on the drive is removed. You should back up any files you want to save by either transfering them to a different drive if you have one, or burning them to CDs/DVDs.
Select the partition you want to install to (if it's a single partition disk, there will only be one listed. If there are more partitions, you can select a different partition to install to which would allow you to keep XP), and I would recommend selecting reformatting the partition to NTFS.
Once it is done reformatting and copying files, it will ask to restart. Restart the computer, but do not press any keys upon startup when it pauses to ask to boot from CD. Wait until the 2K graphical installer loads from the disk, and then you can follow the setup wizard for 2K.
If you have any questions or problems, please add a new post stating them, and I will try to answer.
Dec 14, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot print
Connect your USB lead again and using the HP software, follow the method of setting up wirelessly.
May 06, 2017 | Belkin F1U115E Parallel Switch
Windows NT 4.0 Workstation Drivers?
you need to use windows 2k drivers with windows 2k cant use them on nt
go to battery plus for battery
Feb 21, 2008 | Toshiba Satellite 1715XCDS Notebook
Belkin F1U115E Parallel Switch Logo
284 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
