Click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
SOURCE: My computer (Dell Inspiron 1525)
Hello.
From Click Free Support:
Ensure that the Clickfree device is plugged directly into your computer.
Once connected, wait 3 minutes to confirm the application did not start as expected.
If the application did not start, open your "My Computer"(XP) or "Computer" (Vista / Windows 7.) and check to see if you have both Clickfree_System and Clickfree_Storage.
Double-click on the Clickfree_System drive or browse the Clickfree_System contents and double click StartMyClickfreeBackup.exe.
If the Clickfree™ application starts and begins a backup, then Autorun may be disabled on the computer.
To reenable AutoRun:
FOR XP USERS:
To re-enable Autorun you have to go and download the official Microsoft Windows XP Autorun Repair Wizard. http://www.microsoft.com/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b389cfacdad&displaylang=en Please follow the steps outlined by Microsoft on how to use this repair tool.
FOR VISTA USERS:
To re-enable Autorun, go to Control Panel and select Autoplay. Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
FOR Windows 7 USERS:
To re-enable Autorun, go to Control Panel and select Autoplay (If you do not have the Autoplay option, In the upper right Click on "Category" and select "large icons". You will then be able to select autoplay.) Choose the Restore Defaults button in the Autoplay window which is located at the lower left hand corner.
It's also possible that the ClickFree USB cable is defective. Replace if necessary.
Hope this helps.
SOURCE: My old computer (XP) crashed.
I see. Try to restart your computer, if the computer is completely opened try to check if it worked. If not, try to uninstall it then restart your computer, after restarting re-install it then check it if it will work perfectly.
Thanks.
