Question about HP Officejet 7130 All-In-One InkJet Printer
Printer my printer is showing replace ink cartridge and i did, and now is showing replace cartridge and supply expired ican not print scan and fax please help.
  • 2 more comments
  • carineros Nov 26, 2007
    Hi, I have the same problerm, I have changed the cartridge and now it is saying supply expired, replace black cartridge. I cannot print, copy or fax, any one with a solution.
  • Anonymous Dec 05, 2007
    Did any1 get a soloution as i have the same problem!
  • Brian B Dec 07, 2007
    I think maybe I ran my black cartridge too low on my hp7130xi all-in-one. It has worked flawlessly for years! Now get error message Supply Expires. Replace black ink cartridge. Press enter to continue.
    So I put in new cartridge and it says Press enter to Align Printheads and it just returns to main menu with date and time and there is no movement.
    Also get supply expires when trying to copy. It is as if printer is in closed loop of software. When checking ink level it now says 89% yet will not proceed.
    How do I reset so I can continue
  • abewakil08 Jan 20, 2009
    I have the HP 7130xl and still tells me about cartridge expired. I did remove the battery and it unfort. did not fix the problem. Any other suggestions please
Top Solution thanks - Take that HP!
Slight amendment as battery is hard to remove:
The battery is accessed by opening top then can be seen on extreme left at front. No need to take it out, slip a strip of plastic like an old credit card under the clip on top of battery to insulate it. Then do a soft reset (# and 6 and power down) with the battery insulated. Power up - Power down, remove insulator power up. Eureka!
Posted on Aug 05, 2008
Go to HP site at h10025.www.hp.com and follow their step by step instructions for cleaning cartridges and checking grey latch below ink cartridges. Just might work, otherwise take in for service. Good luck, Brian B
Posted on Dec 07, 2007
  • Brian B Dec 08, 2007
    Still working on the problem. Used the Hp site and eliminated a few ideas but finally went on the 800 # and spoke to a guy name Butch, from India of course, a stage name? Well he was not too helpful so I explored the web more and realized that I might have some print head problems. On reset found magenta and yellow were bad. Then calling to find them. Most office supply stores do not carry but did find them at Fry's Electronics here in San Jose, CA.
    Still not fixed but trying to eliminate problems.
    Any suggestions?
    Brian B
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Thanks BillyBean!
Posted on Mar 12, 2010
Removed battery and soft reset worked for me!
Posted on Jul 27, 2008
The removal of the battery fix posted on Mar 29, 08 worked for me an my HP OfficeJet dD135.
Thank you very much who ever posted that solution.
Posted on May 19, 2008
I did try the battery removal (lower left-Inside on motherboard extention) and it didn't work. Then did a soft reset (# and 6 and power down) with the batery removed. powered back up (Still no battery) Powered down, reinstalled the battery, powered up and was
able to print. No expired message at all!
JM
Posted on Mar 29, 2008
My HP 7130xl was telling me that my ink cartridges were expired (which they were) and refused to print. Knowing full well that the cartridges last well beyond their expiration date, and refusing to talk with HP in India, I found (through a little Googling) that if you remove the printers battery, the printer will no longer be able to read the date on the chip on the cartridge. Works for me--hope it helps you. EM
Posted on Mar 11, 2008
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
Won't fax without ink
This is a Inkjet printer, i needs ink cartridge to be filled to function properly.
Please replace ink cartridges. You cannot print with one ink tank.
Regards,
Riztech
Mar 04, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Says Black ink supply expired. Installed new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
I changed the ink cartridge the black one but it still says cartridge empty I unplugged it and it still sais the same thing
My MFC-420CN acts up occationally. Remove the new cartridge, hold it as you would to install it, Rotate it to the right about 45°. Snap it with the back of a finger (dislodges any air bubbles in ink feed). Reinstall cartridge (ensure it is fully seated. This works for both Brother cartridges and the eforcity cartridges I've been using for the past couple of years. HTH
Lou
Oct 17, 2009 | Brother MFC-685cw InkJet Printer
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Officejet 7130 All-In-One InkJet Printer Logo
1,329 people viewed this question
Clive
Clive
